hippiman
Bartpe Not Working. Need help building it.
I got Bart's PE builder from their site, and it runs perfectly.
When it finally gets done building the BartPE data, I copy it to a CD, and when that's done, I'm able to run it from inside Windows. The only problem is, it won't boot to the CD.
I've already gone into the BIOS and made sure that my computer was set to boot to CD, and I even tried other CDs, and I could boot from them fine.
I've tried making a disk from the files on Windows XP Pro SP2, and on Windows XP Home SP2.
When I run the builder, it always gives me one warning, saying that "building from an OEM version of Windows can mean trouble..." Then I looked that up on google, and they said to try using a Dell fix, and I tried that and it didn't work. I actually didn't think it would, either, because it wasn't a Dell disk that I used to build it.
I'm using the newest version of the PE builder.
If anyone has any advice at all, I'd appreciate it.
