nadazy
Eshop Problem Need help
I uploaded an Eshop System to my webhosting http://forums.xisto.com/no_longer_exists/, according to the installation instruction of Eshop, after finishing upload, I should set up parameter of this Eshop. However, when I entered into my website http://forums.xisto.com/no_longer_exists/, there is nothing to show but a "WELCOM TO YOUR HOSTING ACCOUNT!" page. How can I do now, please kindly help. Thanks!
Edited by nadazy (see edit history)
the shopping cart appears to be in a folder named "install", and as mentioned, the default index.html is still on your account.you need to delete the index.html and consider installing the shopping cart in the root folder or change the .htaccess to start the account at the install/index.php (probably not a good idea). install directories typically should be deleted due to the security risks involved.
