paulmason411
Ie 6 Display Problem unexpected background color
First off, change the "image" tags to "img" and that will eliminate 4 errors on the page.Then run the page through the w3c validator to see if the other warnings tell you anything.Post back here after you do those two things.*edit*###Newsflash###IE6 doesn't do png images. So, the problem is solved by changing the png's into jpg file types or, if you need transparency on them, into gif images.Alternately, there are javascript solutions, but it is simpler to alter the images into gif's.
The javascript that I used for the pngs conflicted with the javascript for the scrollbar. So instead i've gone with the jpg option.Now I have a problem with the scrollbar, once again it looks great in firefox but not so great in IE 6.I think it might be a border or margin problem. Any suggestions?
What sort of Problem?
I don't seem to be able to duplicate it. It looks fine in FF and IE to me. Please describe the specific problem better.
Thanks.
