BooZker 0 Report post Posted October 18, 2007 <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://forums.xisto.com/no_longer_exists/ xmlns="http://forums.xisto.com/no_longer_exists/; xml:lang="en" lang="en"><head> <title>Home</title> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/> <link rel="stylesheet" type="text/css" href="style.css" /> <!--[if IE 6]> <link rel="stylesheet" type="text/css" href="ie6style.css" /> <![endif]--></head> OK that's my code. I have been using IE conditionals for awhile and never had any problems. Now it wont work at all. I have tried so many different ways and nothing works. I would prefer it to be in the /css directory, but i dont know, it didn't work there so i tried the root. you can view this file at http://forums.xisto.com/no_longer_exists/FF and Safari it looks like it is supposed to (and i didn't design just slicing it for a client)IE6 is having the issues and I just want to put a conditional in there and it will fix it all. The top shadow you see in FF and Safari should be gone in IE6 because i took it out to test it. So you can see if the shadow that shadow is gone. Share this post Link to post Share on other sites
chaosdesign 0 Report post Posted October 18, 2007 BooZker said: <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://forums.xisto.com/no_longer_exists/ xmlns="http://forums.xisto.com/no_longer_exists/; xml:lang="en" lang="en"><head> <title>Home</title> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/> <link rel="stylesheet" type="text/css" href="style.css" /> <!--[if IE 6]> <link rel="stylesheet" type="text/css" href="ie6style.css" /> <![endif]--></head>OK that's my code. I have been using IE conditionals for awhile and never had any problems. Now it wont work at all. I have tried so many different ways and nothing works. I would prefer it to be in the /css directory, but i dont know, it didn't work there so i tried the root. you can view this file at http://forums.xisto.com/no_longer_exists/FF and Safari it looks like it is supposed to (and i didn't design just slicing it for a client)IE6 is having the issues and I just want to put a conditional in there and it will fix it all. The top shadow you see in FF and Safari should be gone in IE6 because i took it out to test it. So you can see if the shadow that shadow is gone.What you need is the condition before the normal style sheetA basic form of this is the If-Then-Else statmentIf (logic happenes ie Browser),Then (use this style sheet)Else (or if logic isn't true then use this style sheet)The above just gives you an idea of how to approach the situation. Share this post Link to post Share on other sites
jlhaslip 4 Report post Posted October 18, 2007 Nope, he has it right. Load the main css file first and then the IE css file only needs to contain the rules that should change if the Browser is an IE and meets the contitional. The Conditional can be used to select specific IE versions, too. <!--[if IE 6]>Special instructions for IE 6 here<![endif]-->From http://www.quirksmode.org/css/condcom.html Looks good to me. Check the file path? and remember that the references to images inside the css file should be referenced from the CSS file, not the HTML file. *** edit *** you are missing the style for the nav container in ie css file so the styling from the non-ie stylesheet is continuing to affect the NavContainer, which is likely the problem you are having. Share this post Link to post Share on other sites
mahirharoon 0 Report post Posted December 1, 2007 no problem with ie6 when checked Share this post Link to post Share on other sites
