lionking729 0 Report post Posted June 10, 2007 Completely forgotten where it is, want to turn of the sound IE7 makes when you click a link etc.... Share this post Link to post Share on other sites
Saint_Michael 3 Report post Posted June 10, 2007 Step 1: Go to control PanelStep 2: Click on Sounds Speech and Audio DevicesStep 3: Click on Chane Sound SchemeStep 4: Where it says Program Events Scroll Down until you see Windows ExplorerStep 5: Select none and then click okORStep 1: Open up Internet ExplorerStep 2: Click on tools then Internet optionsStep 3: Click on the advance tabStep 4: Scroll Down till you see MultimediaStep 5: Uncheck the box to play sounds on web pagesStep 6: Press ok and you are set. Share this post Link to post Share on other sites
electriic ink 1 Report post Posted June 10, 2007 If you have Windows XP SP2, then: Start -> Control PanelDouble click on Sounds and Audio Devices Click on the Sounds tabIn the Program Events box, select Start NavigationSelect None from the drop down menuClick OK Share this post Link to post Share on other sites
Mariana 0 Report post Posted June 11, 2007 Wow, thanks. I was needing it xD I just updated my IE and that click sound annoyed me so much. You saved me of the pain of having to hear it everytime I clicked in a link... Share this post Link to post Share on other sites
