hscorp 0 Report post Posted April 18, 2007 my site http://forums.xisto.com/no_longer_exists/ hosted with Xisto - Web Hosting and working on yabsoft image hosting script also this site imagefilez. is the same hosted here and working on yabsoft image hosting script my problem is the url upload http://forums.xisto.com/no_longer_exists/ it gives me a white page after upload when i checked the script company it said theres is a problem in the hosting site check there customer service but in imagefilez the upload working good and i don't why any one now the solution? i forgot to say that i've checked the script on personal server on my machine and it's working good also some features not working in the admin area Share this post Link to post Share on other sites
OpaQue 15 Report post Posted April 18, 2007 Ask the support people, What functions on Server are required and what they feel we should do. We are ready to tweak settings to make your site work.Thanks,Shree Share this post Link to post Share on other sites
jlhaslip 4 Report post Posted April 18, 2007 Just curious, but if you upload an Image using the link at Xisto - Web Hosting, is the Image actually uploaded? or does the upload fail?Is the Image stored in a mysql database? Are the permissions set for the temp and permanent folders to be writable? What version of PHP is the code written using? Share this post Link to post Share on other sites
hscorp 0 Report post Posted April 18, 2007 Just curious, but if you upload an Image using the link at Xisto - Web Hosting, is the Image actually uploaded? or does the upload fail?i don't know which uploading method you meanIs the Image stored in a mysql database?noAre the permissions set for the temp and permanent folders to be writable?yes i've checked themWhat version of PHP is the code written using?i don't knowOpaque please check this >>>>i've uploaded file sent by the script company to check the System Requirement i've got this error i don't know if it the paroblem or not Checking Post Method #1:Function fsockopen() enabledwarning,can not post data via https!Checking URL Upload:Function fsockopen() enabled Share this post Link to post Share on other sites
Saint_Michael 3 Report post Posted April 18, 2007 haslip is referring to the actual uploading of the image, in which once you get the error to do you refresh your browser and go to the gallery to see if its there or not. Also I did a some research and these are the system requirements for the gallery: # PHP 4.2.0 or better# MySQL 3.23 or better# GD2 or Imagemagick# Access to cron jobs# [optional]Mod_rewrite on apache now I am assuming that the "or better" is referring to PHP 4.x.x and not PHP5. A recommendation I would make is check yabsoft's forum since they would have the stronger support to your problems, but make sure you give your php version, MySQL version and other info they might need for this. Share this post Link to post Share on other sites
OpaQue 15 Report post Posted May 9, 2007 # PHP 4.2.0 or better [PRESENT]# MySQL 3.23 or better [PRESENT]# GD2 or Imagemagick [GD LATEST]# Access to cron jobs [PRESENT] Share this post Link to post Share on other sites
