Mike 0 Report post Posted November 18, 2004 I can't log into my Admin CP! It says my IP Address does not match the one in their records (which I don't understand). Is there any way that I can get into the CP? Share this post Link to post Share on other sites
NeXDesigns 0 Report post Posted November 18, 2004 I can't log into my Admin CP! It says my IP Address does not match the one in their records (which I don't understand). Is there any way that I can get into the CP? <{POST_SNAPBACK}> are you using a new computer? Share this post Link to post Share on other sites
NuHoaXuLa 0 Report post Posted November 19, 2004 Wow , if you config invision power board indentify unique a ip then you must use correct that ip to access in acp !If you is webmaster ,you can repair it in your database . I know much hosting company use ip to allow access in your control panel , them only allow ip register host access in host control panel ! If you change ip or use new ip , please contact with hosting company to set ip again ! Share this post Link to post Share on other sites
