arbd
Expandable Tables Problem
Firstly, I suggest you not use the html editor on the Trap Server simply because it places an unneccesary demand on the server when the file editting is still in the build/test stage, so use your local text-editor and check it in your Browser locally before uploading.Secondly, your page is table-based and I don't work on table-based pages, so I really can't help you except to suggest you learn all about css and use Div's for layout. The use of tables for Layout is so 90'ish and there are greater benefits to learning css layouts. It makes cleaner, faster loading sites which are tons easier to maintain.Thirdly, what you do next is place some content and Navigation links into what you already have built. It looks good so far, at least to me.(see suggestion above).Fourthly,There is always somone around that will assist you do what you want or need to do, but we can't guess at what you are trying to do on your site, so I suggest you ask more specific questions. Example: I have a basic page design here, but need to know about building a link list for my Navigation on this site I have created. Then we know what you are having trouble with.Lastly, Since there is no direction as per item 4 above, I will close this Topic. Consider item number 4 above and start a new topic in the HTML section once you have a more specific question. Thanks for understanding.
Guest
