beastjo 0 Report post Posted August 27, 2006 (edited) i've made a better well i think it's better signature using gimp! it's this: Edited August 27, 2006 by beastjo (see edit history) Share this post Link to post Share on other sites
Dawiss 0 Report post Posted August 27, 2006 Its deffinatly better then you previos sig.. but maybe if there is such posibility at gimp to make thous letters a stroke 1px black would be good.. good job .. Share this post Link to post Share on other sites
God-Of-Earth 0 Report post Posted August 27, 2006 Yeah its better. Now your getting the hang try and figure out effects like stroke shadows and whatever else they have in gimp coz i have never used it. But keep it up and keep at it. Share this post Link to post Share on other sites
shadowx 0 Report post Posted August 27, 2006 (edited) Yes it is better, the colours suit much better with the text and the image laid over the background. you could try adding texture into the text by using some of the scripts pre-installed. make a background or some text and then on the toolbar at the top try some of the things under "Script-fu" and just mess around, of you dont like something just press CTRL-Z and undo it youll find there are some very interesting things you can do using those scripts :DKeep it coming! Edited August 27, 2006 by shadowx (see edit history) Share this post Link to post Share on other sites
beastjo 0 Report post Posted August 27, 2006 This is the newest sig i made i know the grey text doesn't look good but i couldn't find a coulor that did i tryed a new texture at the background. Here it is: Share this post Link to post Share on other sites
God-Of-Earth 0 Report post Posted August 27, 2006 well you have good ideas. I would just suggest spending a little longer on your sigs and trying every possible thing. A good design will take time. At the same time you will get the hang of what all the effects do. Trust me bro dont be in a rush to start throwing out loads of sigs quickly because you can make them. When you get good people will respect you for taking your time. Share this post Link to post Share on other sites
beastjo 0 Report post Posted August 27, 2006 This is my newest and best sig yet i tryed new things and found this cool lava effect!! here it is: Share this post Link to post Share on other sites
shadowx 0 Report post Posted August 27, 2006 Youre definately getting the hang of the gimp.One other thing you could try is called bump mapping.Create two layers (press CTRL+L and click on the make new layer button at the bottom, it looks like a new page.) Now call it anything you like.Draw a patern on it using black on a white background. Once done add a blur (filters>blur>gaussian) and use the default values of 5. then click ok. Now go back to the layers window (CTRL+L) and make this new layer below the first layer by clicking the down arrow. If it doesnt move just rename the first layer to whatever you want as sometimes it wont mvoe a layer called "background". Now go Filters>Map>bump mapin the top drop down menue select the layer where you drew the design in black and white this should then show you a preview of the image. it should then look like it has been stamped with the design you drew. Then click okThat can be usefull sometimes Share this post Link to post Share on other sites
God-Of-Earth 0 Report post Posted August 27, 2006 I think somebody likes my sig anyway. Yeah you just need to work at adding more time and lyers to your bgs to make them better. you getting the hang of it though. Share this post Link to post Share on other sites
s2k6 0 Report post Posted August 28, 2006 Blend the text and the render. To blend a render, magic wand, right click, feather then press delete a few times. At leat I think you can do hat in GIMP. Get photoshop, photoshop pwns. Share this post Link to post Share on other sites
beastjo 0 Report post Posted August 28, 2006 I have no idea how to blend if anyone knows please pm me or post it here. Share this post Link to post Share on other sites
