God-Of-Earth 0 Report post Posted August 22, 2006 i just downloaded some fonts for the first time for use in photoshop. Can anybody tell me which folder i put them in in my PS folder. i cant seem to find any fonts folder or files in presets so im not too sure about it. Thanks for your help. Share this post Link to post Share on other sites
apurva 0 Report post Posted August 22, 2006 you just have to install them on your pc in C:\WINDOWS\Fonts Share this post Link to post Share on other sites
Dawiss 0 Report post Posted August 22, 2006 Download and extract the font zip (if its in .zip .rar or other file) then take the .ttf or something like that named font (------.ttf).. Then open Start -> Settings -> Control Panel and there you will find something like a folder named "Fonts" drag and drop your font in it and wait till it loads in there.. next time you want to write something just look for that font name at font list .. Share this post Link to post Share on other sites
apurva 0 Report post Posted August 22, 2006 i don't need to do all this to make the font work in photoshop.. I had just installed the font on my pc and those are available to use in photoshop.. Share this post Link to post Share on other sites
fffanatics 0 Report post Posted August 22, 2006 Yeah photoshop pulls fonts from your c:\windows\fonts directory. All you have to do is put the fonts in there and then restart photoshop if it is currently running so i can reproduce a list of fonts from the directory. Share this post Link to post Share on other sites
BooZker 0 Report post Posted August 23, 2006 Just like all of the others said. UnzipCopy and paste or cut and paste into the C:/windows/fontsLast is just shut off photoshop if it's running and start it back up. Share this post Link to post Share on other sites
