clouds421
Problem With Accessing Website Issue Another problem...
It's not with Xisto, but I have another webpage hosted on a freehost and someone told me they couldn't access it... for as far as I know, this is the only person having that problem.Then I tried testing it out, and it looks like that person can't access anything on that host's servers, so curious what factors could be causing this. It's just really weird to me, because she said that she did get into it once, but could not later on...Yeah, I can host it somewhere else, but this is really never encountered a problem like this so it's baffling.
If they can't access anything on that particular server, then it is most likely that either the server has blocker her IP address or her ISP has blocked that servers ip address. Most likely the 2nd one. This probably happened because someone hosting a site on the server spammed her ISP and they blocked it. This is my best guess. If everyone else can access a server and you are the only one that can't, it usually means some blocking is involved. Of course, this is assuming that this is the only server you can't access. If you can't access other servers as well, then it is probably your computer blocking the server (firewall, etc.)...
<{POST_SNAPBACK}>
no9t9, thanks for you answer! That makes sense. Then are these blocks usually temporary?
