Bkag
Help With Https
Hi im developing a new shopping system for my site but for the login and create account the default is for the page to be on HTTPS but i cannot get that to work however if i change the scripting to "use https" to false it works how can i solve this? i am guessing the page isnt on the https side of the server how do i access it? im so confused? the site is Link here is the code
// * DIR_FS_* = Filesystem directories (local/physical)// * DIR_WS_* = Webserver directories (virtual/URL)
define('HTTP_SERVER', 'http://forums.xisto.com/no_longer_exists/'); // eg, LOCALHOST - should not be empty for productive servers
define('HTTPS_SERVER', 'http://forums.xisto.com/no_longer_exists/'); // eg, LOCALHOST - should not be empty for productive servers
define('ENABLE_SSL', false); // secure webserver for checkout procedure?
define('HTTP_COOKIE_DOMAIN', 'simcards-r-us.co.uk');
define('HTTPS_COOKIE_DOMAIN', '');
define('HTTP_COOKIE_PATH', '/Shop/');
define('HTTPS_COOKIE_PATH', '/Shop/');
define('DIR_WS_HTTP_CATALOG', '/Shop/');
define('DIR_WS_HTTPS_CATALOG', '/Shop/');
The Xisto server does not support SSL. To get SSL, you're probably going to need to go out and buy it. However, I may be wrong, if so, someone please correct me.
You need a whole server app to run in the background for HTTPS. Xisto would need to install it. Use a Yahoo or Ebay store if you want a secure transaction.
Cause Xisto will have it installed on the ROOT DIR for use with all sercure parts of there systems. However i don't believe SSL is free? So providing that would be another cost for Xisto.Just use PHP to out link to a sercure yahoo shopping system or the like.
