jlhaslip 4 Report post Posted April 1, 2006 print "Or you can always... <a href=city.php>go back</a>.";Remove the period at the end of this line and see if that works. It might be trying to concatenate something there???*edit* Browser troubles, fixing it up... Share this post Link to post Share on other sites
shadowdemon 0 Report post Posted April 1, 2006 print "Or you can always... <a href=city.php>go back</a>.";Remove the period at the end of this line and see if that works. It might be trying to concatenate something there???*edit* Browser troubles, fixing it up... no still parse error sry about taking so long boredom troubles Share this post Link to post Share on other sites
truefusion 3 Report post Posted April 1, 2006 if ($action == construct) {Put quotes around construct, see if that helps. Cause unless construct is a constant, it would need quotes, i guess.And if that doesnt help, have you tried echo, rather than, print? Share this post Link to post Share on other sites
shadowdemon 0 Report post Posted April 1, 2006 if ($action == construct) {Put quotes around construct, see if that helps. Cause unless construct is a constant, it would need quotes, i guess.And if that doesnt help, have you tried echo, rather than, print? with echo it doesnt work and with quotes it doesnt. Im getting so mad at this script. ARGGGH why wont it work. Share this post Link to post Share on other sites
truefusion 3 Report post Posted April 2, 2006 (edited) Try this: <?phpinclude ("header.php");echo "Welcome to the construction site. Randomly we will update this place with stuff you can do. Currently we are offering you to make a building where you can make trade gold for ap or platinum for ap. The cost of this project is all 10k silver wood.";if ($stat[construction] <= 1){print "Would you like to start the building";echo "<a href=\"construction.php?action=construct\">construct</a>";}if ($action == "construct"){print "you have started construction $stat[user]...<br /><br />";mysql_query("Update players Set construction=yes where id=stat[id]");//a verification should be made if the player has the right amount of silver wood before making that query//else you'll end up with - numbers..mysql_query("Update players Set silver wood = $stat[silverwood]-10000 where stat[id]");mysql_query("Update players Set construction = stat[construction]+1 where stat[id]");print "</table><br />";print "Or you can always... <a href=\"city.php\">go back</a>.";}if ($stat[constructed] >= 2){$prices = mysql_query("select * from market");$pa = mysql_fetch_array($prices);$plat_price = $pa[ap];if ($action != "buy") {print "Ap isn't always a stable-priced commodity... right now its $plat_price credits an ap. How much you want?";print "<form method=\"post\" action=\"construction.php?action=buy\">";print "I want <input type=\"text\" name=\"plat\"> ap. <input type=\"submit\" value=\"Buy\">";print "</form>";}else {$plat = str_replace("--","", $plat);$cost = ($plat * $plat_price);if ($cost > $stat[credits] || $plat <= 0) {print "You cant afford that! (<a href=\"pshop.php\">back</a>)";}else {mysql_query("update players set credits=credits-$cost where id=$stat[id]");mysql_query("update players set ap=ap+$plat where id=$stat[id]");print "You got <b>$plat</b> ap for <b>$cost</b> credits.";}}}include ("footer.php");?> Edited April 2, 2006 by truefusion (see edit history) Share this post Link to post Share on other sites
shadowdemon 0 Report post Posted April 2, 2006 Well i asked a old firend of mine on another site to help and he figured it out. Share this post Link to post Share on other sites
