lecius 0 Report post Posted November 20, 2005 Well I was doing everything right with my phpbb and everything was going great.I tried to install the cashmod and it said it worked but it didn't because the admin panel for phpBB was tottaly screwed and I could only see the right side page. I tried to reinstall phpBB but in the cpanel it is gone and I can't manul install it because it says I can't.Anyone know what to do? Share this post Link to post Share on other sites
jlhaslip 4 Report post Posted November 20, 2005 Uninstall the mod. Uninstall the phpbb. Delete the mysql and start over.If the problem only happened with the mod install, review the manual and try again. Share this post Link to post Share on other sites
lecius 0 Report post Posted November 20, 2005 I used easymod to install it, I don't know how to install phpBB or how to install mysql, and when I installed phpBB it was one of thoes already waiting to be installed thingies. Share this post Link to post Share on other sites
vujsa 0 Report post Posted November 20, 2005 So to reinstall phpBB, you'll have to manually delete the origina; one first along with it's DB. That data seems to have not made the shift from the old server.Basically, just delete alll of the unwanted files.Next tiime ebesure that the mode is compatable with your current version and template.vujsa Share this post Link to post Share on other sites
lecius 0 Report post Posted November 20, 2005 That does not help either, I want to delete the whole forum file but it will no let me, It will not delete the cache file so it will not delete the forum file. Share this post Link to post Share on other sites
vujsa 0 Report post Posted November 20, 2005 lecius (11/20/05 2:41 pm) -- The installation can not be completed:Did you geta reason from the installer?Did you get all of the old files deleted first?How much disk spcae do you have left?vujsa Share this post Link to post Share on other sites
cragllo 0 Report post Posted November 21, 2005 First delete all files, delete the MySQL database via cPanel, delete all your logs, make sure you have anough space and then install it again. Share this post Link to post Share on other sites
