jae-unit 0 Report post Posted October 5, 2005 Well i can't acess Fantastico at all. When I click on the link, it just goes blank forever, or has an error page. Does anyone know how to fix this? Share this post Link to post Share on other sites
Gyad 0 Report post Posted October 5, 2005 Hmm...Thats really strange. I'm using the Fantastico page right now and theres no problem at all. Have you tried using a different brower or clearing your cookies? (Clearing cookies might not really help though...) Share this post Link to post Share on other sites
cragllo 0 Report post Posted October 5, 2005 Sometimes cPanel and Fantastico can be a bit slow, if you are using Internet Explorer, it will usualy take forever to load, If you use one that dosent support useless features, it will load much faster. Share this post Link to post Share on other sites
jae-unit 0 Report post Posted October 5, 2005 Well this is what happens when I try to get on that page: Share this post Link to post Share on other sites
kevlar557 0 Report post Posted October 5, 2005 You're picture will not show up on the page. It says"User Posted Image" Share this post Link to post Share on other sites
wassie 0 Report post Posted October 5, 2005 i see you i tried it too in your cpanel. you get this error:Parse error: parse error, unexpected $ in /tmp/cpanel.jaeunit.1128544817.32301 on line 126i tested my own fantastico and that works fine...if i were you i would mail OpaQue about this.greetzwassie Share this post Link to post Share on other sites
Dragonfly 0 Report post Posted October 21, 2005 It could be when the database of the server is busy or unstable due to overloading of the server. Fantastico too uses scripts that should be executed but could be interrupted due to problem in the server. i've just tested mine to see if anything is wrong in it, but mine is working perfectly.Try again later. Share this post Link to post Share on other sites
