shadowdemon
Help With A Code
i may be bugging people with this but wats wrong with this code
$db = mysql_select_db("shadow_member",$connection)    or die ("couldn't select databse.");
i enetered this code in another code so it would connect to the datavase were the table is but i got this message when i tested it out
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /home/shadow/public_html/join.php on line 13
Well, it sounds like you have not made a connection to the database yet... Have you called the mysql_connect() function? And have you passed it valid parameters??
You should do something like:
$connection = mysql_connect( "server", "username", "password" );$db = mysql_select_db( "shadow_member", $connection )    or die ("couldn't select databse.");
I hope that helps!!
Oh, and if you have used the connect statement already, then make sure it is correct..
here is the code that realy works for me and im assuming for everybody too :ph34r: of course..mysql_connect('localhost', 'username', 'password');mysql_select_db('database');so the error is you put 2 arguments to the function mysql_select_db()when it only need one..its a better idea too to use single qoutation mark to speed up compiling
Server is usually "localhost". Like post #3 has it.
yeah you should used 'localhost' if the mysql you are connecting is not in some other server in the web but in your webhost server. if your are using mysql in Xisto webhosting use 'localhost' as server, your cpanel name as user and your cpanel password as password. That should work.
