SlvrDragon50 0 Report post Posted September 14, 2005 ok.. i use photoshop to make my sig.. of course.. i only know how to make the background that changes color and text.. what iw ant to know is how do you make a picture blend in? if i need another program that would help me.. please reccomend a FREE one. Share this post Link to post Share on other sites
icemarle 0 Report post Posted September 15, 2005 Hm... Photoshop can do pretty much anything. To make it blend, go to the picture's layer and play around with the settings. There's a pull-down menu there, and it's initially "Normal" Change that and pick the setting that you want. I'm sorry I couldn't tell you exactly what it is, since I don't have Photoshop open right now. I'm low on memory, and opening it would make it worse... Share this post Link to post Share on other sites
leiaah 0 Report post Posted September 15, 2005 (edited) there's already a post about blending renders. i dug it up for you. I hope this helps. blending rendersSorry, here's another one about renders. i think you should start with this one. Adding A Render To A Sig Notice from wassie: Merged posts Edited September 15, 2005 by wassie (see edit history) Share this post Link to post Share on other sites
