AMWGeek 0 Report post Posted September 9, 2005 (edited) I was just about finish with my new subsite AmazingRed when I notioced next to the update box is a white line, which should be there. Anything think they can help me?The code.. <body background="http://forums.xisto.com/no_longer_exists/bg1.jpg&%2334; leftmargin="0" topmargin="0" rightmargin="0" bottommargin="0"> Edited September 9, 2005 by OpaQue (see edit history) Share this post Link to post Share on other sites
tigen28 0 Report post Posted September 9, 2005 The original picture has whitelines on it; so enlarging it to fit the whole webpage would still maintain its propertities.I do not understand what you are saying, nor am I sure of any "update box" I do not see any "update box." All I see is black background with white linesCan you clarify more? Share this post Link to post Share on other sites
OpaQue 15 Report post Posted September 9, 2005 The Box in the center which has update written on it must be the UPDATE box he is referring to. I don't understand his query either and I dont see any white lines. Share this post Link to post Share on other sites
AMWGeek 0 Report post Posted September 9, 2005 The update box is the table thing on the far right with Update in it, but don't worry about it. I'm just going to leave it how it is. Thanks anyway, though. Share this post Link to post Share on other sites
guangdian 0 Report post Posted September 9, 2005 the code was all right .no problem sir.you need give your error page..and you need know what's the web standards.(webstandards.org)then you will not need tabletag for the page frame or margin then you will use CSS. Share this post Link to post Share on other sites
sunkist 0 Report post Posted September 18, 2005 Hi:I see a black box with red text in it. The box is outlined in white. That all looks fine to me. Is that what you are not satisfied with?Sunkist Share this post Link to post Share on other sites
