josh_sg1 0 Report post Posted October 9, 2004 i need a good file transferercan you guy's help me out? Share this post Link to post Share on other sites
s2city 0 Report post Posted October 9, 2004 what do you mean? like an FTP Client? CuteFTP and CoreFTP are good for that. Or are you asking for something that transfers files from PC - PC? Reply with some more detail, and I'll try to lend a hand Share this post Link to post Share on other sites
xc3ll 0 Report post Posted October 11, 2004 yeah, really dude, u should be more specific, there are so many ways 2 do what u want that i could prolly make a page long list of software that u could use....u should really make longer posts.... Share this post Link to post Share on other sites
s2city 0 Report post Posted October 12, 2004 CoreFTP is what I use. I really love it. If you get the Standard version, it's free. If you need like advanced things...not really sure what they are, but there is an Advanced version of it. But all the features you need are in the Standard version. Permission settings, multiple file uploads, drag and drop uploading, or you can click a button to upload. It's so much better then anything else available. You can download it from http://download.cnet.com/windows/. Share this post Link to post Share on other sites
bowti3 0 Report post Posted October 12, 2004 Leap FTP is also free and it works good with many features. http://forums.xisto.com/no_longer_exists/ Share this post Link to post Share on other sites
DarkHell 0 Report post Posted October 23, 2004 i use ws_ftp pro (i think thats how it is spelled), one of best ftp programs i ever used Share this post Link to post Share on other sites
finaldesign 0 Report post Posted November 3, 2004 I use Cuteftp too. I think that cftp is best ftp program of all times. No, really it's fuly user friendly, compatible & compact, quck and accessible... When you start using Cuteftp, you will never want to use another ftp program. really. Share this post Link to post Share on other sites
psychiccyberfreak 0 Report post Posted November 9, 2004 yeah, I use core ftp too. Its great, and Ive never had an issue with it. Also, if you use frontpage, or dreamweaver, there's a built in ftp client that you have to set up first, but definately worth it!!! Share this post Link to post Share on other sites
campusjunk 0 Report post Posted November 10, 2004 I've used WS_ftp pro, aceftp and cuteftp, and i've found ws works good but is slower than ace. Ace has always been the fastest out of all 3, cuteftp just kinda... welll its there. But sometimes ace wont work.. wont be able to login, like when the server is bogged down really bad. But WS_ftp pro will basically always work, but will be really slow. So if i cant get a login with ace, then i use ws. But ace is quicker so it is my preffered ftp program. I've never tried core.. i might have to. (edit)I've now tried flashfxp, and smartftp.. and i think that flash is good. Sometimes I cant get it to log on and then i go back to ws_ftp. But those 2 are my favorites. Not a big fan of ACEFTP any more. Share this post Link to post Share on other sites
