patelg 0 Report post Posted August 6, 2005 My DVD Burner makes lots of noise, while reading CD. Any suggestion in fixing this noise.It is LITE-ON DVDRW.Any suggestion is welcome.Thanks in advanced. Share this post Link to post Share on other sites
RGPHNX 0 Report post Posted August 7, 2005 Hi patelg,Not much you can do about it except make sure it's clean & your using the correct type of media/CDs/DVDs. If it does it at "high" burn speed & NOT at low speed..then the drive bearings are probably going bad. - not something you can fix yourself. Other causes of noise could be a bad read/write head tracking arm..again not something you can replace yourself.Hope this is clear.RGPHNX Share this post Link to post Share on other sites
patelg 0 Report post Posted August 8, 2005 Hi patelg, Not much you can do about it except make sure it's clean & your using the correct type of media/CDs/DVDs. If it does it at "high" burn speed & NOT at low speed..then the drive bearings are probably going bad. - not something you can fix yourself. Other causes of noise could be a bad read/write head tracking arm..again not something you can replace yourself. Hope this is clear. RGPHNX 171916[/snapback] So I have to prepare myself buying one......i hope it will break while within warrentty!!!!! Thanks for the info.... Share this post Link to post Share on other sites
guangdian 0 Report post Posted August 8, 2005 sometimes this is not a problem i thinkany part of the computer will all do lots of noise but not only dvd burner.your harddisk,your cpu your graphic card all this noise.anyhow i think the biggest noise is the hardisk Share this post Link to post Share on other sites
faith 0 Report post Posted August 8, 2005 I recommend just buying a new one **ebay** no one trusts ebay but im sure you can find a very good burner there, or anywehere else at that matter, i wouldnt feel right having a noisy burnder, ide freak out screaming that its broke. Share this post Link to post Share on other sites
