mizako
X does not start X does not start
Hi,
I am using a knoppix 3.3 distro with a 2.4.24 kernel in my box.
I tried to install recently KDE 3.3. All the modules are installed ok except of kdebindings and kdewebdev. Both fail due to compilat errors. I upgraded to gcc 4.3 (I had previously gcc 3.4) but they still fail. Here is the kdebindings log:
[/br]x_11.cpp: In function `void xcall_KSharedConfig(short int, void*, Smoke::StackItem*)':[br]x_11.cpp:8219: warning: unused variable 'xself'[/br]In file included from libsmokekde_la.all_cpp.cpp:17:[br]x_15.cpp: At global scope:[/br]x_15.cpp:4659: internal compiler error: Segmentation fault[br]Please submit a full bug report,[/br]with preprocessed source if appropriate.[br]See <gcc bugsl> for instructions.[/br]make[4]: *** [libsmokekde_la.all_cpp.lo] Error 1[br]make[4]: Leaving directory `/home/sergio/konstruct/kde/kdebindings/work/kdebindings-3.3.0/smoke/kde'[/br]make[3]: *** [all-recursive] Error 1[br]make[3]: Leaving directory `/home/sergio/konstruct/kde/kdebindings/work/kdebindings-3.3.0/smoke'[/br]make[2]: *** [all-recursive] Error 1[br]make[2]: Leaving directory `/home/sergio/konstruct/kde/kdebindings/work/kdebindings-3.3.0'[/br]make[1]: *** [all] Error 2[br]make[1]: Leaving directory `/home/sergio/konstruct/kde/kdebindings/work/kdebindings-3.3.0'[/br]make: *** [build-work/kdebindings-3.3.0/Makefile] Error 2[br][/br]This is a pre-release version of XFree86, and is not supported in any[br]way.  Bugs may be reported to XFree86@XFree86.Org and patches submitted[/br]to fixes@XFree86.Org.  Before reporting bugs in pre-release versions,[br]please check the latest version in the XFree86 CVS repository[br][/br][/br]XFree86 Version 4.3.0.1 (Debian 4.3.0.dfsg.1-4 20040529113443 root@cyberhq.internal.cyberhqz.com)[br]Release Date: 15 August 2003[/br]X Protocol Version 11, Revision 0, Release 6.6[br]Build Operating System: Linux 2.6.6-rc3-bk9 i686 [ELF] [/br]Build Date: 29 May 2004[br]    Before reporting problems, check [/br]    to make sure that you have the latest version.[br]Module Loader present[/br]OS Kernel: Linux version 2.4.24-xfs (root@Knoppix) (gcc version 2.95.4 20011002 (Debian prerelease)) #1 SMP Mi Feb 4 01:03:50 CET 2004 [br]Markers: (--) probed, (**) from config file, (==) default setting,[/br]         (++) from command line, (!!) notice, (II) informational,[br]         (WW) warning, (EE) error, (NI) not implemented, (??) unknown.[/br](==) Log file: "/var/log/XFree86.0.log", Time: Tue Oct  5 20:06:40 2004[br](==) Using config file: "/etc/X11/XF86Config-4"[/br](==) ServerLayout "XFree86 Configured"[br](**) |-->Screen "Screen0" (0)[/br](**) |   |-->Monitor "Monitor0"[br](**) |   |-->Device "Card0"[/br](**) |-->Input Device "Keyboard0"[br](**) Option "XkbRules" "xfree86"[/br](**) XKB: rules: "xfree86"[br](**) Option "XkbModel" "pc105"[/br](**) XKB: model: "pc105"[br](**) Option "XkbLayout" "es"[/br](**) XKB: layout: "es"[br](==) Keyboard: CustomKeycode disabled[/br](**) |-->Input Device "PS/2 Mouse"[br](WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/truetype".[/br]    Entry deleted from font path.[br]    (Run 'mkfontdir' on "/usr/share/fonts/truetype").[/br](WW) The directory "/usr/X11R6/lib/X11/fonts/defoma/CID" does not exist.[br]    Entry deleted from font path.[/br](WW) The directory "/usr/X11R6/lib/X11/fonts/defoma/TrueType" does not exist.[br]    Entry deleted from font path.[/br](**) FontPath set to "/usr/X11R6/lib/X11/fonts/misc:unscaled,/usr/X11R6/lib/X11/fonts/misc,/usr/X11R6/lib/X11/fonts/75dpi:unscaled,/usr/X11R6/lib/X11/fonts/75dpi,/usr/X11R6/lib/X11/fonts/100dpi:unscaled,/usr/X11R6/lib/X11/fonts/100dpi,/usr/X11R6/lib/X11/fonts/Speedo,/usr/X11R6/lib/X11/fonts/PEX,/usr/X11R6/lib/X11/fonts/cyrillic,/usr/X11R6/lib/X11/fonts/Type1,/usr/share/fonts/ttf/western,/usr/share/fonts/ttf/decoratives,/usr/share/fonts/truetype/openoffice,/usr/share/fonts/truetype/ttf-bitstream-vera,/usr/share/fonts/latex-ttf-fonts"[br](**) RgbPath set to "/usr/X11R6/lib/X11/rgb"[/br](**) ModulePath set to "/usr/X11R6/lib/modules"[br](**) Option "AllowMouseOpenFail" "true"[/br](--) using VT number 7[br][/br](II) Open APM successful[br](II) Module ABI versions:[/br]    XFree86 ANSI C Emulation: 0.2[br]    XFree86 Video Driver: 0.6[/br]    XFree86 XInput driver : 0.4[br]    XFree86 Server Extension : 0.2[/br]    XFree86 Font Renderer : 0.4[br](II) Loader running on linux[/br](II) LoadModule: "bitmap"[br](II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a[/br](II) Module bitmap: vendor="The XFree86 Project"[br]    compiled for 4.3.0.1, module version = 1.0.0[/br]    Module class: XFree86 Font Renderer[br]    ABI class: XFree86 Font Renderer, version 0.4[/br](II) Loading font Bitmap[br](II) LoadModule: "pcidata"[/br](II) Loading /usr/X11R6/lib/modules/libpcidata.a[br](II) Module pcidata: vendor="The XFree86 Project"[br]    compiled for 4.3.0.1, module version = 1.0.0[/br]    ABI class: XFree86 Video Driver, version 0.6[/br](II) PCI: Probing config type using method 1[br](II) PCI: Config type is 1[/br](II) PCI: stages = 0x03, oldVal1 = 0x00000000, mode1Res1 = 0x80000000[br](II) PCI: PCI scan (all values are in hex)[/br](II) PCI: End of PCI scan[br](II) Bus -1: bridge is at (0:2:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)[/br](--) PCI:*(1:0:0) Silicon Integrated Systems [SiS] SiS315PRO PCI/AGP VGA Display Adapter rev 0, Mem @ 0xb0000000/28, 0xcfec0000/18, I/O @ 0xbc00/7, BIOS @ 0xcfeb0000/16[br](II) LoadModule: "ddc"[/br](II) Loading /usr/X11R6/lib/modules/libddc.a[br](II) Module ddc: vendor="The XFree86 Project"[br]    compiled for 4.3.0.1, module version = 1.0.0[/br]    ABI class: XFree86 Video Driver, version 0.6[/br](II) LoadModule: "GLcore"[br](II) Loading /usr/X11R6/lib/modules/extensions/libGLcore.a[/br]Skipping "/usr/X11R6/lib/modules/extensions/libGLcore.a:m_debug_clip.o":  No symbols found[br]Skipping "/usr/X11R6/lib/modules/extensions/libGLcore.a:m_debug_norm.o":  No symbols found[/br]Skipping "/usr/X11R6/lib/modules/extensions/libGLcore.a:m_debug_xform.o":  No symbols found[br]Skipping "/usr/X11R6/lib/modules/extensions/libGLcore.a:m_debug_vertex.o":  No symbols found[/br](II) Module GLcore: vendor="The XFree86 Project"[br]    compiled for 4.3.0.1, module version = 1.0.0[/br]    ABI class: XFree86 Server Extension, version 0.2[br](II) LoadModule: "dbe"[/br](II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a[br](II) Module dbe: vendor="The XFree86 Project"[br]    compiled for 4.3.0.1, module version = 1.0.0[/br]    Module class: XFree86 Server Extension[/br]    ABI class: XFree86 Server Extension, version 0.2[br](II) Loading extension DOUBLE-BUFFER[/br](II) LoadModule: "dri"[br](II) Loading /usr/X11R6/lib/modules/extensions/libdri.a[/br](II) Module dri: vendor="The XFree86 Project"[br]    compiled for 4.3.0.1, module version = 1.0.0[/br]    ABI class: XFree86 Server Extension, version 0.2[br](II) Loading sub module "drm"[/br](II) LoadModule: "drm"[br](II) Loading /usr/X11R6/lib/modules/linux/libdrm.a[/br](II) Module drm: vendor="The XFree86 Project"[br]    compiled for 4.3.0.1, module version = 1.0.0[/br]    ABI class: XFree86 Server Extension, version 0.2[br](II) Loading extension XFree86-DRI[/br](II) LoadModule: "extmod"[br](II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a[/br](II) Module extmod: vendor="The XFree86 Project"[br]    compiled for 4.3.0.1, module version = 1.0.0[/br]    Module class: XFree86 Server Extension[br]    ABI class: XFree86 Server Extension, version 0.2[/br](II) Loading extension SHAPE[br](II) Loading extension MIT-SUNDRY-NONSTANDARD[/br](II) Loading extension BIG-REQUESTS[br](II) Loading extension SYNC[/br](II) Loading extension MIT-SCREEN-SAVER[br](II) Loading extension XC-MISC[/br](II) Loading extension XFree86-VidModeExtension[br](II) Loading extension XFree86-Misc[/br](II) Loading extension XFree86-DGA[br](II) Loading extension DPMS[/br](II) Loading extension FontCache[br](II) Loading extension TOG-CUP[/br](II) Loading extension Extended-Visual-Information[br](II) Loading extension XVideo[/br](II) Loading extension XVideo-MotionCompensation[br](II) Loading extension X-Resource[/br](II) LoadModule: "glx"[br](II) Loading /usr/X11R6/lib/modules/extensions/libglx.a[/br](II) Module glx: vendor="The XFree86 Project"[br]    compiled for 4.3.0.1, module version = 1.0.0[/br]    ABI class: XFree86 Server Extension, version 0.2[br](II) Loading sub module "GLcore"[/br](II) LoadModule: "GLcore"[br](II) Reloading /usr/X11R6/lib/modules/extensions/libGLcore.a[/br](II) Loading extension GLX[br](II) LoadModule: "bitmap"[/br](II) Reloading /usr/X11R6/lib/modules/fonts/libbitmap.a[br](II) Loading font Bitmap[/br](II) LoadModule: "speedo"[br](II) Loading /usr/X11R6/lib/modules/fonts/libspeedo.a[/br]Skipping "/usr/X11R6/lib/modules/fonts/libspeedo.a:spencode.o":  No symbols found[br](II) Module speedo: vendor="The XFree86 Project"[/br]    compiled for 4.3.0.1, module version = 1.0.1[br]    Module class: XFree86 Font Renderer[br]    ABI class: XFree86 Font Renderer, version 0.4[/br](II) Loading font Speedo[/br](II) LoadModule: "type1"[br](II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a[/br](II) Module type1: vendor="The XFree86 Project"[br]    compiled for 4.3.0.1, module version = 1.0.2[/br]    Module class: XFree86 Font Renderer[br]    ABI class: XFree86 Font Renderer, version 0.4[/br](II) Loading font Type1[br](II) Loading font CID[/br](II) LoadModule: "freetype"[br](II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.a[/br](II) Module freetype: vendor="The XFree86 Project"[br]    compiled for 4.3.0.1, module version = 2.0.2[/br]    Module class: XFree86 Font Renderer[br]    ABI class: XFree86 Font Renderer, version 0.4[/br](II) Loading font FreeType[br](II) LoadModule: "record"[/br](II) Loading /usr/X11R6/lib/modules/extensions/librecord.a[br](II) Module record: vendor="The XFree86 Project"[/br]    compiled for 4.3.0.1, module version = 1.13.0[br]    Module class: XFree86 Server Extension[/br]    ABI class: XFree86 Server Extension, version 0.2[br](II) Loading extension RECORD[/br](II) LoadModule: "vesa"[br](II) Loading /usr/X11R6/lib/modules/drivers/vesa_drv.o[/br](II) Module vesa: vendor="The XFree86 Project"[br]    compiled for 4.3.0.1, module version = 1.0.0[/br]    Module class: XFree86 Video Driver[br]    ABI class: XFree86 Video Driver, version 0.6[/br](II) LoadModule: "mouse"[br](II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o[/br](II) Module mouse: vendor="The XFree86 Project"[br]    compiled for 4.3.0.1, module version = 1.0.0[/br]    Module class: XFree86 XInput Driver[br]    ABI class: XFree86 XInput driver, version 0.4[/br](II) VESA: driver for VESA chipsets: vesa[br](II) Primary Device is: PCI 01:00:0[/br](--) Assigning device section with no busID to primary device[br](--) Chipset vesa found[/br]*(WW) (1920x1440,Monitor0) mode clock 234MHz exceeds DDC maximum 110MHz[br](WW) (1920x1440,Monitor0) mode clock 297MHz exceeds DDC maximum 110MHz[/br](WW) (1920x1440,Monitor0) mode clock 341.35MHz exceeds DDC maximum 110MHz[br](II) VESA(0): Not using built-in mode "1920x1440" (hsync out of range)[/br](II) VESA(0): Total Memory: 512 64KB banks (32768kB)[br](WW) VESA(0): config file hsync range 30-72kHz not within DDC hsync range 30-69kHz[/br](WW) VESA(0): config file vrefresh range 50-160Hz not within DDC vrefresh range 50-120Hz[br](II) VESA(0): Monitor0: Using hsync range of 30.00-72.00 kHz[/br](II) VESA(0): Monitor0: Using vrefresh range of 50.00-160.00 Hz[br](--) VESA(0): Virtual size is 1024x768 (pitch 1024)[/br](**) VESA(0): *Built-in mode "1024x768"[br](**) VESA(0): *Built-in mode "800x600"[/br](**) VESA(0): *Built-in mode "640x480"[br](**) VESA(0):  Built-in mode "640x400"[/br](--) VESA(0): Display dimensions: (280, 210) mm[br](--) VESA(0): DPI set to (92, 92)[/br](WW) (1024x768,Monitor0) mode clock 113.31MHz exceeds DDC maximum 110MHz[br](II) VESA(0): Attempting to use 75Hz refresh for mode "1024x768" (117)[/br](II) VESA(0): Attempting to use 100Hz refresh for mode "800x600" (114)[br](II) VESA(0): Attempting to use 100Hz refresh for mode "640x480" (111)[/br](II) VESA(0): Attempting to use 85Hz refresh for mode "640x400" (139)[br](**) VESA(0): Using "Shadow Framebuffer"[/br](II) Loading sub module "shadow"[br](II) LoadModule: "shadow"[/br](II) Loading /usr/X11R6/lib/modules/libshadow.a[br](II) Module shadow: vendor="The XFree86 Project"[br]    compiled for 4.3.0.1, module version = 1.0.0[/br]    ABI class: XFree86 ANSI C Emulation, version 0.2[/br](II) Loading sub module "fb"[br](II) LoadModule: "fb"[/br](II) Loading /usr/X11R6/lib/modules/libfb.a[br](II) Module fb: vendor="The XFree86 Project"[br]    compiled for 4.3.0.1, module version = 1.0.0[/br]    ABI class: XFree86 ANSI C Emulation, version 0.2[/br](II) do I need RAC?  No, I don't.[br](II) resource ranges after preInit:[/br](II) Loading sub module "int10"[br](II) LoadModule: "int10"[/br](II) Reloading /usr/X11R6/lib/modules/linux/libint10.a[br](II) VESA(0): initializing int10[/br](II) VESA(0): Primary V_BIOS segment is: 0xc000[br](II) VESA(0): VESA BIOS detected[/br](II) VESA(0): VESA VBE Version 3.0[br](II) VESA(0): VESA VBE Total Mem: 32768 kB[/br](II) VESA(0): VESA VBE OEM: SiS[br](II) VESA(0): VESA VBE OEM Software Rev: 1.0[/br](II) VESA(0): VESA VBE OEM Vendor: Silicon Integrated Systems Corp.[br](II) VESA(0): VESA VBE OEM Product: 315[/br](II) VESA(0): VESA VBE OEM Product Rev: 1.13.03[br](==) VESA(0): Write-combining range (0xb0000000,0x2000000)[/br](II) VESA(0): virtual address = 0x4027f000,[br]    physical address = 0xb0000000, size = 33554432[/br](==) VESA(0): Default visual is TrueColor[br](==) VESA(0): Backing store disabled[/br](**) Option "dpms" "true"[br](**) VESA(0): DPMS enabled[/br](==) RandR enabled[br](II) Setting vga for screen 0.[/br](II) Initializing built-in extension MIT-SHM[br](II) Initializing built-in extension XInputExtension[/br](II) Initializing built-in extension XTEST[br](II) Initializing built-in extension XKEYBOARD[/br](II) Initializing built-in extension LBX[br](II) Initializing built-in extension XC-APPGROUP[/br](II) Initializing built-in extension SECURITY[br](II) Initializing built-in extension XINERAMA[/br](II) Initializing built-in extension XFree86-Bigfont[br](II) Initializing built-in extension RENDER[/br](II) Initializing built-in extension RANDR[br](II) Keyboard "Keyboard0" handled by legacy driver[/br](**) Option "Protocol" "IMPS/2"[br](**) PS/2 Mouse: Protocol: "IMPS/2"[/br](**) Option "SendCoreEvents" "true"[br](**) PS/2 Mouse: always reports core events[/br](**) Option "CorePointer"[br](**) PS/2 Mouse: Core Pointer[/br](**) Option "Device" "/dev/psaux"[br](**) Option "Emulate3Buttons" "true"[/br](**) Option "Emulate3Timeout" "70"[br](**) PS/2 Mouse: Emulate3Buttons, Emulate3Timeout: 70[/br](**) Option "ZAxisMapping" "4 5"[br](**) PS/2 Mouse: ZAxisMapping: buttons 4 and 5[/br](**) PS/2 Mouse: Buttons: 5[br](II) XINPUT: Adding extended input device "PS/2 Mouse" (type: MOUSE)[/br](II) PS/2 Mouse: ps2EnableDataReporting: succeeded[br]Warning: font renderer for ".pcf" already registered at priority 0[/br]Warning: font renderer for ".pcf.Z" already registered at priority 0[br]Warning: font renderer for ".pcf.gz" already registered at priority 0[/br]Warning: font renderer for ".snf" already registered at priority 0[br]Warning: font renderer for ".snf.Z" already registered at priority 0[/br]Warning: font renderer for ".snf.gz" already registered at priority 0[br]Warning: font renderer for ".bdf" already registered at priority 0[/br]Warning: font renderer for ".bdf.Z" already registered at priority 0[br]Warning: font renderer for ".bdf.gz" already registered at priority 0[/br]Warning: font renderer for ".pmf" already registered at priority 0[br]
My XF86Config-4 file is the next:
[/br]Section "ServerLayout"[/br]    Identifier     "XFree86 Configured"[br]    Screen      0  "Screen0" 0 0[/br]    InputDevice    "Keyboard0" "CoreKeyboard"[br]    InputDevice    "PS/2 Mouse" "CorePointer"[/br]# Serial Mouse not detected[br]# USB Mouse not detected[/br]EndSection[br][/br]Section "ServerFlags"[br]    Option "AllowMouseOpenFail"  "true"[/br]    [br]EndSection[br][/br]Section "Files"[/br]    RgbPath      "/usr/X11R6/lib/X11/rgb"[br]    ModulePath   "/usr/X11R6/lib/modules"[/br]    FontPath     "/usr/X11R6/lib/X11/fonts/misc:unscaled"[br]    FontPath     "/usr/X11R6/lib/X11/fonts/misc"[/br]    FontPath     "/usr/X11R6/lib/X11/fonts/75dpi:unscaled"[br]    FontPath     "/usr/X11R6/lib/X11/fonts/75dpi"[/br]    FontPath     "/usr/X11R6/lib/X11/fonts/100dpi:unscaled"[br]    FontPath     "/usr/X11R6/lib/X11/fonts/100dpi"[/br]    FontPath     "/usr/X11R6/lib/X11/fonts/Speedo"[br]    FontPath     "/usr/X11R6/lib/X11/fonts/PEX"[/br]# Additional fonts: Locale, Gimp, TTF...[br]    FontPath     "/usr/X11R6/lib/X11/fonts/cyrillic"[/br]#   FontPath     "/usr/X11R6/lib/X11/fonts/latin2/75dpi"[br]#   FontPath     "/usr/X11R6/lib/X11/fonts/latin2/100dpi"[/br]# True type and type1 fonts are also handled via xftlib, see /etc/X11/XftConfig![br]    FontPath     "/usr/X11R6/lib/X11/fonts/Type1"[/br]    FontPath     "/usr/share/fonts/ttf/western"[br]    FontPath     "/usr/share/fonts/ttf/decoratives"[/br]    FontPath     "/usr/share/fonts/truetype"[br]    FontPath     "/usr/share/fonts/truetype/openoffice"[/br]    FontPath     "/usr/share/fonts/truetype/ttf-bitstream-vera"[br]    FontPath     "/usr/share/fonts/latex-ttf-fonts"[/br]    FontPath     "/usr/X11R6/lib/X11/fonts/defoma/CID"[br]    FontPath     "/usr/X11R6/lib/X11/fonts/defoma/TrueType"[/br]EndSection[br][/br]Section "Module"[br]        Load  "ddc"  # ddc probing of monitor[/br]    Load  "GLcore"[br]    Load  "dbe"[/br]    Load  "dri"[br]    Load  "extmod"[/br]    Load  "glx"[br]        Load  "bitmap" # bitmap-fonts[/br]    Load  "speedo"[br]    Load  "type1"[/br]    Load  "freetype"[br]    Load  "record"[/br]EndSection[br][/br]Section "InputDevice"[br]    Identifier  "Keyboard0"[/br]    Driver      "keyboard"[br]        Option      "CoreKeyboard"[/br]    Option "XkbRules" "xfree86"[br]    Option "XkbModel" "pc105"[/br]    Option "XkbLayout" "es"[br][/br]EndSection[br][/br]Section "InputDevice"[br]    Identifier  "Serial Mouse"[/br]    Driver      "mouse"[br]    Option      "Protocol" "Microsoft"[/br]    Option      "Device" "/dev/ttyS0"[br]    Option      "Emulate3Buttons" "true"[/br]    Option      "Emulate3Timeout" "70"[br]    Option      "SendCoreEvents"  "true"[/br]EndSection[br][/br]Section "InputDevice"[br]    Identifier  "PS/2 Mouse"[/br]    Driver      "mouse"[br]    Option      "Protocol" "IMPS/2"[/br]    Option      "ZAxisMapping"          "4 5"[br]    Option      "Device" "/dev/psaux"[br]    Option      "Emulate3Buttons" "true"[/br]    Option      "Emulate3Timeout" "70"[br]    Option      "SendCoreEvents"  "true"[/br]EndSection[br][/br]Section "InputDevice"[/br]        Identifier      "USB Mouse"[br]        Driver          "mouse"[/br]        Option          "Device"                "/dev/input/mice"[br]        Option      "SendCoreEvents"    "true"[/br]        Option          "Protocol"              "IMPS/2"[br]        Option          "ZAxisMapping"          "4 5"[/br]        Option          "Buttons"               "5"[br]EndSection[br][/br]# Auto-generated by KNOPPIX mkxf86config[br][/br]Section "Monitor"[/br]    Identifier  "Monitor0"[br]    Option  "DPMS"  "true"[/br]    VendorName  "FUS"[br]    ModelName   "FUS0210"[/br]    HorizSync 30 - 72 # DDC-probed[br]    VertRefresh 50 - 160 # DDC-probed[/br]    # These are the DDC-probed settings reported by your monitor.[br]    # 1024x768, 75.0Hz; hfreq=60.02, vfreq=75.03[/br]    ModeLine "1024x768"  78.75 1024 1040 1136 1312  768  769  772  800 +hsync +vsync[br]    # 1024x768, 75.0Hz; hfreq=60.02, vfreq=75.03[/br]    ModeLine "1024x768"  78.75 1024 1040 1136 1312  768  769  772  800 +hsync +vsync[br]    # 800x600, 85.0Hz; hfreq=53.67, vfreq=85.06[/br]    ModeLine "800x600"   56.25  800  832  896 1048  600  601  604  631 +hsync +vsync[br]    # 800x600, 75.0Hz; hfreq=46.88, vfreq=75.00[/br]    ModeLine "800x600"   49.50  800  816  896 1056  600  601  604  625 +hsync +vsync[br]    # 800x600, 60.0Hz; hfreq=37.88, vfreq=60.32[/br]    ModeLine "800x600"   40.00  800  840  968 1056  600  601  605  628 +hsync +vsync[br]    # 640x480, 85.0Hz; hfreq=43.27, vfreq=85.01[/br]    ModeLine "640x480"   36.00  640  696  752  832  480  481  484  509 -hsync -vsync[br]    # 640x480, 75.0Hz; hfreq=37.50, vfreq=75.00[/br]    ModeLine "640x480"   31.50  640  656  720  840  480  481  484  500 -hsync -vsync[br]    # 640x480, 60.0Hz; hfreq=31.47, vfreq=59.94[/br]    ModeLine "640x480"   25.17  640  648  744  784  480  482  484  509 -hsync -vsync[br]    # Extended modelines with GTF timings[/br]    # 640x480 @ 100.00 Hz (GTF) hsync: 50.90 kHz; pclk: 43.16 MHz[br]    ModeLine "640x480"  43.16  640 680 744 848  480 481 484 509  -HSync +Vsync[/br]    # 768x576 @ 60.00 Hz (GTF) hsync: 35.82 kHz; pclk: 34.96 MHz[br]    ModeLine "768x576"  34.96  768 792 872 976  576 577 580 597  -HSync +Vsync[/br]    # 768x576 @ 72.00 Hz (GTF) hsync: 43.27 kHz; pclk: 42.93 MHz[br]    ModeLine "768x576"  42.93  768 800 880 992  576 577 580 601  -HSync +Vsync[/br]    # 768x576 @ 75.00 Hz (GTF) hsync: 45.15 kHz; pclk: 45.51 MHz[br]    ModeLine "768x576"  45.51  768 808 888 1008  576 577 580 602  -HSync +Vsync[/br]    # 768x576 @ 85.00 Hz (GTF) hsync: 51.42 kHz; pclk: 51.84 MHz[br]    ModeLine "768x576"  51.84  768 808 888 1008  576 577 580 605  -HSync +Vsync[/br]    # 768x576 @ 100.00 Hz (GTF) hsync: 61.10 kHz; pclk: 62.57 MHz[br]    ModeLine "768x576"  62.57  768 816 896 1024  576 577 580 611  -HSync +Vsync[/br]    # 800x600 @ 100.00 Hz (GTF) hsync: 63.60 kHz; pclk: 68.18 MHz[br]    ModeLine "800x600"  68.18  800 848 936 1072  600 601 604 636  -HSync +Vsync[/br]    # 1024x768 @ 100.00 Hz (GTF) hsync: 81.40 kHz; pclk: 113.31 MHz[br]    ModeLine "1024x768"  113.31  1024 1096 1208 1392  768 769 772 814  -HSync +Vsync[/br]    # 1152x864 @ 60.00 Hz (GTF) hsync: 53.70 kHz; pclk: 81.62 MHz[br]    ModeLine "1152x864"  81.62  1152 1216 1336 1520  864 865 868 895  -HSync +Vsync[/br]    # 1152x864 @ 85.00 Hz (GTF) hsync: 77.10 kHz; pclk: 119.65 MHz[br]    ModeLine "1152x864"  119.65  1152 1224 1352 1552  864 865 868 907  -HSync +Vsync[/br]    # 1152x864 @ 100.00 Hz (GTF) hsync: 91.50 kHz; pclk: 143.47 MHz[br]    ModeLine "1152x864"  143.47  1152 1232 1360 1568  864 865 868 915  -HSync +Vsync[/br]    # 1280x960 @ 72.00 Hz (GTF) hsync: 72.07 kHz; pclk: 124.54 MHz[br]    ModeLine "1280x960"  124.54  1280 1368 1504 1728  960 961 964 1001  -HSync +Vsync[/br]    # 1280x960 @ 75.00 Hz (GTF) hsync: 75.15 kHz; pclk: 129.86 MHz[br]    ModeLine "1280x960"  129.86  1280 1368 1504 1728  960 961 964 1002  -HSync +Vsync[/br]    # 1280x960 @ 100.00 Hz (GTF) hsync: 101.70 kHz; pclk: 178.99 MHz[br]    ModeLine "1280x960"  178.99  1280 1376 1520 1760  960 961 964 1017  -HSync +Vsync[/br]    # 1280x1024 @ 100.00 Hz (GTF) hsync: 108.50 kHz; pclk: 190.96 MHz[br]    ModeLine "1280x1024"  190.96  1280 1376 1520 1760  1024 1025 1028 1085  -HSync +Vsync[/br]    # 1400x1050 @ 60.00 Hz (GTF) hsync: 65.22 kHz; pclk: 122.61 MHz[br]    ModeLine "1400x1050"  122.61  1400 1488 1640 1880  1050 1051 1054 1087  -HSync +Vsync[/br]    # 1400x1050 @ 72.00 Hz (GTF) hsync: 78.77 kHz; pclk: 149.34 MHz[br]    ModeLine "1400x1050"  149.34  1400 1496 1648 1896  1050 1051 1054 1094  -HSync +Vsync[/br]    # 1400x1050 @ 75.00 Hz (GTF) hsync: 82.20 kHz; pclk: 155.85 MHz[br]    ModeLine "1400x1050"  155.85  1400 1496 1648 1896  1050 1051 1054 1096  -HSync +Vsync[/br]    # 1400x1050 @ 85.00 Hz (GTF) hsync: 93.76 kHz; pclk: 179.26 MHz[br]    ModeLine "1400x1050"  179.26  1400 1504 1656 1912  1050 1051 1054 1103  -HSync +Vsync[/br]    # 1400x1050 @ 100.00 Hz (GTF) hsync: 111.20 kHz; pclk: 214.39 MHz[br]    ModeLine "1400x1050"  214.39  1400 1512 1664 1928  1050 1051 1054 1112  -HSync +Vsync[/br]    # 1600x1200 @ 100.00 Hz (GTF) hsync: 127.10 kHz; pclk: 280.64 MHz[br]    ModeLine "1600x1200"  280.64  1600 1728 1904 2208  1200 1201 1204 1271  -HSync +Vsync[/br]EndSection[br][/br]Section "Device"[br]    ### Available Driver options are:-[/br]# sw_cursor is needed for some ati and radeon cards[br]        #Option     "sw_cursor"[/br]        #Option     "hw_cursor"[br]        #Option     "NoAccel"[/br]        #Option     "ShowCache"[br]        #Option     "ShadowFB"[/br]        #Option     "UseFBDev"[br]        #Option     "Rotate"[/br]    Identifier  "Card0"[br]# The following line is auto-generated by KNOPPIX mkxf86config[/br]    Driver      "vesa"[br]    VendorName  "All"[/br]    BoardName   "All"[br]#   BusID       "PCI:1:0:0"[/br]EndSection[br][/br]Section "Screen"[br]    Identifier "Screen0"[/br]    Device     "Card0"[br]    Monitor    "Monitor0"[/br]    DefaultColorDepth 16[br]    SubSection "Display"[/br]        Depth     1[br]        Modes "1024x768" "800x600" "640x480"[/br]    EndSubSection[br]    SubSection "Display"[/br]        Depth     4[br]        Modes "1024x768" "800x600" "640x480"[/br]    EndSubSection[br]    SubSection "Display"[/br]        Depth     8[br]        Modes "1024x768" "800x600" "640x480"[/br]    EndSubSection[br]    SubSection "Display"[/br]        Depth     15[br]        Modes "1024x768" "800x600" "640x480"[/br]    EndSubSection[br]    SubSection "Display"[/br]        Depth     16[br]        Modes "1024x768" "800x600" "640x480"[/br]    EndSubSection[br]    SubSection "Display"[/br]        Depth     24[br]        Modes "1024x768" "800x600" "640x480"[/br]    EndSubSection[br]    SubSection "Display"[/br]        Depth     32[br]        Modes "1024x768" "800x600" "640x480"[/br]    EndSubSection[br]EndSection[br][/br]Section "DRI"[/br]    Mode 0666[br]EndSection[br]
Thanks in advanced for your help guys. If this is not the right place to post. Please let me know and tell me where should i post.
Sergio del Amo
it seems like u know what ur doing... or u dont, and r just trying 2 make it look like u r....either way, i dont understand why ur installing knoppix on 2 ur hd...... its meant 2 stay on the cd, thats the beauty of it......if u want a distro 4 2 install on ur hd, go w/suse or mandrake or something......if u want the newest version of knoppix, just dl it! ive used it a few times, and never had any problems w/it.....other than that tho, i really cant help ya, im not 2 knowledgeable w/linux....
You might as well use Knoppix installed on your HDD. This more or less translates to Debian. Just grab a fresh copy of Knoppix from their website. It will detect your hardware properly. Install it on your HDD and that's it. The latest one (3.6 if I am not mistaken) comes with KDE 3.3, so that you won't have to worry about updating it.
Tomorow I will get gentoo, so I must install kde 3.3.1 becouse it comes with 3.1, so I will se what is going on and tell you if I finish job good <_<
just one suggestion. Try Fedora core 2 its more hardware supportive. and there are many supportive help is available on net /google too.
Thats *BLEEP* since the support of hardware lays mostly in the kernel, as long as you have 2.6.x you should be fine with the support.
For the topicstarter:
May I ask why you use the "vesa"video drivers since they "suck" and have a bad resolution support.
I see also that you have set:
[br]Option  "DPMS"  "true"[/br]
I have seen lots of problems garding X support with htis option set perhaps it is an idea to try to run it with:
[/br]Option  "DPMS"  "false"[br]
or
[/br]#Option  "DPMS"  "boolean"
For pbrugge:I will give it a change to your suggestion in the next days. Now i have no time. I will let you know as soon as i tried. Thanks everybody for your feedback.
Don't know, I install kde 3.3.1 and it works perfectly. Maybe gcc is not in harmony with glib, g++ and others...? <_<
try this:
press CTRL+ALT and run thru F1 - F7 while pressin CTRL+ALT. If you hit F7 and there's XFree86 server runnin, then you found ur prob. YOU CANNOT RUN more THAN 1 X SERVER*... if not, try the command init 5 or startx
xboxrulz
*Edited 11/05/2004
try this:
press CTRL+ALT and run thru F1 - F7 while pressin CTRL+ALT. If you hit F7 and there's XFree86 server runnin, then you found ur prob. YOU CANNOT RUN more THAN 1 X process... if not, try the command init 5 or startx
xboxrulz
:D nice thinking but dont you think that if he was running an x-server already that linux would have come up with an error himself?
Try to do a startx in vt-2 when you run X and you see what I mean :)
btw not all distros run X in vt-7 (F7) for instance gentoo runs it in vt-8 (F8) and (oke its not linux) freebsd runs it in vt-9 (F9) for default.
greetz...
well, if it is Redhat based, it is VT 7 like SuSE/Mandrake and all that supports RPM. Debian is also F7. Linspire locked their VT surfin function. NOTE: You cannot use F10 because that's the kernel's journal.xboxrulz
