Tseng
Flash Banner I need help editing mine.
Can anyone help me edit a flash banner that I downloaded.It came with a template that I downloaded and I don't know how to fix it. I tried to edit it with a SWF editor but it was too time consuming and I need someone else to do it. If you can then just reply and I will give you the link to the swf file.
By downloading a template, I am guessing you downloaded a .zip file with a .fla and a .swf in it?If so, you need Macromedia Flash to edit the .fla, the .swf is just the movie that isn't editable.If you don't have Macromedia Flash, and you can't afford it, I'm afraid you probably can't edit it, unfortunately (though I highly suggest buying Flash, it's an extremely useful tool).Well, that's my advice anyway.
