Chicken 0 Report post Posted April 29, 2005 When i try to go visit my CPanel, it gives me a 404 error, currently using ie 6 on this computer, please help Share this post Link to post Share on other sites
NilsC 0 Report post Posted April 29, 2005 The 3 ways you should access your cPanel is:http://forums.xisto.com/no_longer_exists/orhttp://forums.xisto.com/no_longer_exists/orhttp://forums.xisto.com/no_longer_exists/If your computer don't let you login using the popup, cances it and login from the web page.I just tested it and it works. and don't forget to use your cPanel username "irot" and not chicken.Nils Share this post Link to post Share on other sites
Chicken 0 Report post Posted May 2, 2005 Ok, after hours of messing around and around and around on the schools computers i come home and try one last time right before i give up and start flaming so i can get my self banned. It works just fine now, the only thing i can come up with, is the school i go to has a proxy protection called "BESS" and i bet thats probably why i couldnt access it, other than that i dunno why it wouldnt work, thank you for your help. Share this post Link to post Share on other sites
guangdian 0 Report post Posted May 2, 2005 It's surely the problem of ISP.I never got this problem.Just enjoy it Chicken~.hah Share this post Link to post Share on other sites
snlildude87 0 Report post Posted May 2, 2005 Problem apparently solved -> thread closedP.S. Don't flame. It's not worth it to lose your account over some anger problems. Share this post Link to post Share on other sites
