DjLuki 0 Report post Posted April 25, 2005 hey..are java scripts allowed? cause i've been trying to put this script..it's like an advertisement.. but it will not allow me.. when i try to put it it gives me this error" These HTML Tags are not allowed? anyone have this problem or know how to fix it? Share this post Link to post Share on other sites
Saint_Michael 3 Report post Posted April 25, 2005 post the script then it will be more helpful to help you Share this post Link to post Share on other sites
DjLuki 0 Report post Posted April 25, 2005 ok thats true.. here is the code/script... <!-- Clicksor.com Advertising Code Begin --><script type='text/javascript'><!--//default house ad urlclicksor_default_url = '';clicksor_enable_pop = false;//--></script><script type='text/javascript' src='http://forums.xisto.com/no_longer_exists/&%2339;<!-- Clicksor.com Advertising Code End --> Share this post Link to post Share on other sites
snlildude87 0 Report post Posted April 25, 2005 JavaScript and advertisement is perfectly legal according to Xisto rules. Unless those are pornographic or warez, then it's a different story.Anyways, I think more information is needed here. For example, what page are you trying to put it on (what is its URL)? What's the code? Where are you trying to put the code in the site? Share this post Link to post Share on other sites
DjLuki 0 Report post Posted April 25, 2005 im trying to put that on my index page.. http://forums.xisto.com/no_longer_exists/ .. itried to put it into that box where you will see a different banner ..i want to replace that..and i just told you the code... are you sure you know waht you're talking about lol.. you asked the same question like 3 times. and this is not porn or warez advertisement. Share this post Link to post Share on other sites
Spectre 0 Report post Posted April 25, 2005 Are you trying to put the code in place through the CMS you're using? I would suggest you edit the raw HTML code if you wish to put this code in place. I doubt that it's Xisto telling you that you can't use the tags, but rather the software package you're using. Share this post Link to post Share on other sites
googlue 0 Report post Posted April 25, 2005 If you type javascript as content in some Content Management System software like PHPnuke or Mambo, it does not accept. You will have to type it in the raw index.php.That's how I have included ads in my site. Share this post Link to post Share on other sites
Saint_Michael 3 Report post Posted April 25, 2005 its conflicting with one of your scripts from it looks like on your website i suggest make a copy of you site then put your advertising script in then one at a time put all your scripts back inthat should help Share this post Link to post Share on other sites
DjLuki 0 Report post Posted April 26, 2005 that's way to much work saint michael.. and i still don't think it would work because ure basically changing nothing.. and i think i'll try what googlue said.. put it in the inex.php.. but which index file? Share this post Link to post Share on other sites
