iGuest
help -- phpnuke userinfo block
hi how do i remove the security code chk in user info block....its not the config.php 1
as seen in
HERE
attached is the code
<?php/************************************************************//* Description.: User Info Block                            *//* Version.....: v0.3.1                                     *//* File Name...: block-User_Info.php                        *//* Last Updated: 10 December 2003                           *//*                                                          *//* Update Release - 19 Jan 2004 - chatserv                  *//* Website http://forums.xisto.com/no_longer_exists/                         *//* 19/01/2004 - Added Points Needed For Group Membership    *//* 19/01/2004 - Added Missing Language Definitions          *//*                                                          *//* Updated for PHP-Nuke 7.x - 10 Dec 2003 - chatserv        *//* Website http://forums.xisto.com/no_longer_exists/                         *//* 10/12/2003 - Added Point Total Display                   *//* 10/12/2003 - Added Site Groups list w/ points needed     *//*                                                          *//* Updated for PHP-Nuke 6.x - 22/07/2003 - NukeZone         *//* Website http://http://www.nukezone.com/                          *//* 22/07/2003 - Added Security Check Image                  *//* 22/07/2003 - Added User logout Link                      *//* 22/07/2003 - Added Admin Logout - Visible to Admin Only  *//*                     ------------                         *//* Updated for PHP-Nuke 5.6 -  18 Jun 2002 NukeScripts      *//* website https://www.hugedomains.com/domain_profile.cfm?d=nukescripts&e=com                       *//*                     ------------                         *//* Updated for PHP-Nuke 5.5 - 24/03/2002 Rugeri             *//* website http://newsportal.homip.net                      *//*                     ------------                         *//* (C) 2002                                                 *//* All rights beyond the GPL are reserved                   *//*                                                          *//************************************************************//* Additional security checking code 2003 by chatserv       *//* http://forums.xisto.com/no_longer_exists/ -- http://forums.xisto.com/no_longer_exists/ *//************************************************************/if (eregi("block-User_Info.php",$_SERVER['PHP_SELF'])) {    Header("Location: index.php");}$content = "";global $user, $admin, $cookie, $prefix, $user_prefix, $db, $anonymous, $sitekey;mt_srand ((double)microtime()*1000000);$maxran = 1000000;$random_num = mt_rand(0, $maxran);$datekey = date("F j");$rcode = hexdec(md5($_SERVER[HTTP_USER_AGENT] . $sitekey . $random_num . $datekey));$code = substr($rcode, 2, 10);cookiedecode($user);$uname = $cookie[1];$lasturow = $db->sql_fetchrow($db->sql_query("SELECT username FROM $user_prefix"._users." ORDER BY user_id DESC LIMIT 0,1"));$lastuser = $lasturow['username'];$numrows = $db->sql_numrows($db->sql_query("SELECT user_id FROM $user_prefix"._users.""));$result = $db->sql_query("SELECT uname, guest FROM $prefix"._session." WHERE guest='0'");$member_online_num = $db->sql_numrows($result);$who_online_now = "";$i = 1;while ($session = $db->sql_fetchrow($result)) {    if (isset($session["guest"]) and $session["guest"] == 0) {        if ($i < 10) {            $who_online_now .= "  0$i: <A HREF="modules.php?name=Your_Account&op=userinfo&username=$session[uname]">$session[uname]</a><br>n";        } else {            $who_online_now .= "  $i: <A HREF="modules.php?name=Your_Account&op=userinfo&username=$session[uname]">$session[uname]</a><br>n";        }        $who_online_now .= ($i != $member_online_num ? "  " : "");        $i++;    }}$Today = getdate();//Formatting Current Date$month = $Today['month'];$mday = $Today['mday'];$year = $Today['year'];//Formatting Previous Date$pmonth = $Today['month'];$pmday = $Today['mday'];$pmday = $mday-1;$pyear = $Today['year'];//Month conversion into numeric modeif ($pmonth=="January") { $pmonth=1; } elseif ($pmonth=="February") { $pmonth=2; } elseif ($pmonth=="March") { $pmonth=3; } elseif ($pmonth=="April") { $pmonth=4; } elseif ($pmonth=="May") { $pmonth=5; } elseif ($pmonth=="June") { $pmonth=6; } elseif ($pmonth=="July") { $pmonth=7; } elseif ($pmonth=="August") { $pmonth=8; } elseif ($pmonth=="September") { $pmonth=9; } elseif ($pmonth=="October") { $pmonth=10; } elseif ($pmonth=="November") { $pmonth=11; } elseif ($pmonth=="December") { $pmonth=12; };$test = mktime (0,0,0,$pmonth,$pmday,$pyear,1);//Creating SQL parameter$curDate2 = "%".$month[0].$month[1].$month[2]."%".$mday."%".$year."%";$preday = strftime ("%d",$test);$premonth = strftime ("%B",$test);$preyear = strftime ("%Y",$test);$curDateP = "%".$premonth[0].$premonth[1].$premonth[2]."%".$preday."%".$preyear."%";//Executing SQL Today$row = $db->sql_fetchrow($db->sql_query("SELECT COUNT(user_id) AS userCount FROM $user_prefix"._users." WHERE user_regdate LIKE '$curDate2'"));$userCount = $row['userCount'];//end//Executing SQL Today$row2 = $db->sql_fetchrow($db->sql_query("SELECT COUNT(user_id) AS userCount FROM $user_prefix"._users." WHERE user_regdate LIKE '$curDateP'"));$userCount2 = $row2['userCount'];//end$guest_online_num = $db->sql_numrows($db->sql_query("SELECT uname FROM ".$prefix."_session WHERE guest='1'"));$member_online_num = $db->sql_numrows($db->sql_query("SELECT uname FROM ".$prefix."_session WHERE guest='0'"));$who_online_num = $guest_online_num + $member_online_num;$grpcnt = "";$i = 1;$gresult = $db->sql_query("SELECT name, points FROM " . $prefix . "_groups ORDER BY points");while ($grow = $db->sql_fetchrow($gresult)) {$grname = $grow['name'];$grpoints = intval($grow['points']);$users_num = $db->sql_numrows($db->sql_query("SELECT * FROM " . $user_prefix . "_users WHERE points>='$grpoints'"));        if ($i < 10) {            $grpcnt .= "  <b>0$i: <u>$grname</u></b><br>  "._NPOINTS.": <b>$grpoints</b><br>  "._SGMEMBERS.": <b>$users_num</b><br>n";        } else {            $grpcnt .= "  <b>$i: <u>$grname</u></b><br>  "._SGMEMBERS.": <b>$users_num</b><br>n";        }        $i++;}$numpoints = $db->sql_fetchrow($db->sql_query("SELECT points FROM ".$user_prefix."_users WHERE username='$uname'"));$npoints = intval($numpoints['points']);$content .= "<form action="modules.php?name=Your_Account" method="post">";if (is_user($user)) {    $content .= "<br><img src="images/blocks/group-4.gif" height="14" width="17"> "._BWEL.", <b>$uname</b>.<br>n";    $content .= "<center>[ <a href="modules.php?name=Your_Account&op=logout">"._LOGOUT."</a> ]</center>n";    if (is_admin($admin) AND is_user($user)) {        $content .= "<br><center>"._ADMIN."<br>[ <a href="admin.php?op=logout">"._LOGOUT."</a> ]</center>n";    }    $content .= "<hr>n";    $row3 = $db->sql_fetchrow($db->sql_query("SELECT user_id FROM $user_prefix"._users." WHERE username='$uname'"));    $uid = $row3['user_id'];    $newpms = $db->sql_numrows($db->sql_query("SELECT privmsgs_to_userid FROM $prefix"._bbprivmsgs." WHERE privmsgs_to_userid='$uid' AND (privmsgs_type='5' OR privmsgs_type='1')"));    $oldpms = $db->sql_numrows($db->sql_query("SELECT privmsgs_to_userid FROM $prefix"._bbprivmsgs." WHERE privmsgs_to_userid='$uid' AND privmsgs_type='0'"));    $content .= "<img src="images/blocks/email-y.gif" height="10" width="14"> <a href="modules.php?name=Private_Messages"><b>"._BPM."</b></a><br>n";    $content .= "<img src="images/blocks/email-r.gif" height="10" width="14"> "._BUNREAD.": <b>$newpms</b><br>n";    $content .= "<img src="images/blocks/email-g.gif" height="10" width="14"> "._BREAD.": <b>$oldpms</b><br>n<hr>n";    $content .= "<img src="images/blocks/icon_poll.gif" height="14" width="17"> <b><u>"._TPOINTS.":</u></b><br>  <b><strong><big>·</big></strong> ".$npoints." <strong><big>·</big></strong></b><hr>n";} else {    $content .= "<center><img src="images/blocks/group-4.gif" height="14" width="17"> "._BWEL.", <b>$anonymous</b>n<hr>";    $content .= ""._NICKNAME."<br><input type="text" name="username" size="10" maxlength="25"><br>";    $content .= ""._PASSWORD."<br><input type="password" name="user_password" size="10" maxlength="20"><br>";    if (extension_loaded("gd")) {	$content .= ""._SECURITYCODE.": <img src='http://forums.xisto.com/no_longer_exists/404.png' border='1' alt='"._SECURITYCODE."' title='"._SECURITYCODE."'><br>n";	$content .= ""._TYPESECCODE."<br><input type="text" NAME="gfx_check" SIZE="7" MAXLENGTH="6">n";	$content .= "<input type="hidden" name="random_num" value="$random_num"><br>n";    } else {	$content .= "<input type="hidden" name="random_num" value="$random_num">";	$content .= "<input type="hidden" name="gfx_check" value="$code">";    }    $content .= "<input type="hidden" name="op" value="login">";    $content .= "<input type="submit" value=""._LOGIN."">n (<a href="modules.php?name=Forums&file=profile&mode=register">"._BREG."</a>)</center><hr>";}$content .= "<img src="images/blocks/icon_members.gif" height="14" width="17"> <b><u>"._SITEGROUPS.":</u></b><br>$grpcnt<hr>n";$content .= "<img src="images/blocks/group-2.gif" height="14" width="17"> <a href="modules.php?name=Members_List"><b><u>"._BMEMP.":</u></b></a><br>n";$content .= "<img src="images/blocks/ur-moderator.gif" height="14" width="17"> "._BLATEST.": <A HREF="modules.php?name=Your_Account&op=userinfo&username=$lastuser"><b>$lastuser</b></a><br>n";$content .= "<img src="images/blocks/ur-author.gif" height="14" width="17"> "._BTD.": <b>$userCount</b><br>n";$content .= "<img src="images/blocks/ur-admin.gif" height="14" width="17"> "._BYD.": <b>$userCount2</b><br>n";$content .= "<img src="images/blocks/ur-guest.gif" height="14" width="17"> "._BOVER.": <b>$numrows</b><br>n<hr>n";$content .= "<img src="images/blocks/group-3.gif" height="14" width="17"> <b><u>"._BVISIT.":</u></b>n<br>n";$content .= "<img src="images/blocks/ur-anony.gif" height="14" width="17"> "._BVIS.": <b>$guest_online_num</b><br>n";$content .= "<img src="images/blocks/ur-member.gif" height="14" width="17"> "._BMEM.": <b>$member_online_num</b><br>n";$content .= "<img src="images/blocks/ur-registered.gif" height="14" width="17"> "._BTT.": <b>$who_online_num</b><br>n";if ($member_online_num > 0) {    $content .= "<hr>n<img src="images/blocks/group-1.gif" height="14" width="17"> <b><u>"._BON.":</u></b><br>$who_online_nown";}$content .= "</form>";?>
not index...config.php you mean...but no...didnt work.....look at the attached code.......i removed some parts the code dissappeared but i got parse error instead....
