iGuest 3 Report post Posted March 7, 2005 I have a problem with photoshop cann somebody help me?the problem is that when I want have a text and I set the front size on 72 it's really small.. to small to read! Share this post Link to post Share on other sites
iGuest 3 Report post Posted March 7, 2005 I am moving this to software Share this post Link to post Share on other sites
iGuest 3 Report post Posted March 7, 2005 Hmmm it had happened to me but i dun remember how but i got it fix. Though one problem may be that ur dun have zoom to 100%. i will look into that when i have time. Probably this thurstday. Share this post Link to post Share on other sites
iGuest 3 Report post Posted March 8, 2005 Try highlighting the text and then setting the font. Share this post Link to post Share on other sites
iGuest 3 Report post Posted March 8, 2005 Reset everything to default. It's one of the options at the top, don't remember which. You probably messed up the settings somewhere. And highlighting won't work. It's a common problem. Share this post Link to post Share on other sites
iGuest 3 Report post Posted March 8, 2005 Try reseting ur photoshop and setting everything to deault, also check the font, some fonts dont like ps. Also what version of ps are you using, that will help me figure out whats wrong.And oh yea, do make sure its at 100% zoom, that happens to alot of people Share this post Link to post Share on other sites
iGuest 3 Report post Posted March 8, 2005 I've had this problem once before. What I did is that I changed the resolution. The standard resolution for "normal" sized texted is 72 pixels/inch (or 28.346 pixel/cm). That should hopefully fix your problem. Share this post Link to post Share on other sites
iGuest 3 Report post Posted March 14, 2005 Maybe you have at 25% zoom. get this to 100% and thats all!Or ask on good-tutorials.com for help!! Share this post Link to post Share on other sites
