dozen 0 Report post Posted September 8, 2004 I installed phpnuke to playt around with it because i was bored but, i didnt notice that i couldnt install it when i had phpbb installed, because i only have 20 mb still, now, i try to remove it, the name for the phpnuke thing isnt there, how do i delete it.. ive used up all my mb because of this thing =/. Share this post Link to post Share on other sites
wassie 0 Report post Posted September 8, 2004 well you can also delete it at your cpanel,go to the derectery of phpnuke,and you can delete it there...else use your ftp client to delete the files...+WARNING+-if you use your ftp client to delete this... you could get errors at your cpanel- Share this post Link to post Share on other sites
dozen 0 Report post Posted September 8, 2004 i went to public_html > and some other things, you can lock this now :] Share this post Link to post Share on other sites
wassie 0 Report post Posted September 8, 2004 oke :P/CLOSED Share this post Link to post Share on other sites
