truvu17 0 Report post Posted September 5, 2004 Hi folks, I have VB6 and when I tried to install it, it pops up with saying shell.dll was not found and that installation cant find that specific file or other files to install VB6. If anybody know whats the problem, please let me know. Thanks. Share this post Link to post Share on other sites
Zenchi 0 Report post Posted September 5, 2004 I've checked some search engines and come up with nothing. Have you installed the previous VB Runtimes? Other then that, what system are you using, and are you using an alternitive shell? Share this post Link to post Share on other sites
madeinaustria 0 Report post Posted September 21, 2004 I had a similar problem, but it was not the shell.dll. the only way was a reinstall of my machine. i also found no solution on the www Share this post Link to post Share on other sites
Spectre 0 Report post Posted September 21, 2004 *Thread moved. Share this post Link to post Share on other sites
dundun2007 0 Report post Posted September 21, 2004 it was probably a bad install i install it a while back and everything worked fine, so i have never experienced that problem, but i think that it a bad install. So my suggestion is just reinstalling it. Share this post Link to post Share on other sites
akz 0 Report post Posted September 24, 2004 Try reinstalling again I had the same problem.. but if its still the same I think you should check your disc or your cd rom drive.. cause you never know.. Share this post Link to post Share on other sites
magiccode9 0 Report post Posted May 1, 2006 hi, I have't this problems yet. Which version is the OS of your computer?I have installed it over win95, win2000, win2000 w/sp4 and winxp w/sp1May be media damage, may be hardware problems.Would you mind list the hardware settings of your computer? Share this post Link to post Share on other sites
shadowx 0 Report post Posted May 1, 2006 One thing you could do, as already said is to download the VB runtimes. They can normally be found by searching the web. This will normally come as an exe which installs dll files and registry entreied (i belive) which make VB run. This might not be a 100% solution but its a good step to try first of all.Is it a new disk you bought from a shop or some other form (eg free download etc...)? if its a brand new disk from a shop then it might already have some runtimes on the disk so you could try looking inside the disk. Share this post Link to post Share on other sites
