iGuest 3 Report post Posted December 31, 2004 hi i get sorry there seems to be a problem with the sql db... this is my config.php <?php /************************************************************************/ /* PHP-NUKE: Advanced Content Management System */ /* ============================================ */ /* */ /* Copyright © 2002 by Francisco Burzi */ /* https://www.phpnuke.org/ */ /* */ /* This program is free software. You can redistribute it and/or modify */ /* it under the terms of the GNU General Public License as published by */ /* the Free Software Foundation; either version 2 of the License. */ /* */ /************************************************************************/ /* Additional security checking code 2004 by chatserv */ /* http://forums.xisto.com/no_longer_exists/ -- http://www.nukeresources.com/ */ /************************************************************************/ /* PHP-Nuke Platinum: Expect to be impressed COPYRIGHT */ /* */ /* Copyright © 2004 - 2006 by http://www.techgfx.com/ */ /* Techgfx - Graeme Allan (goose@techgfx.com) */ /* */ /* Copyright © 2004 - 2006 by http://www.conrads-berlin.de/ */ /* MrFluffy - Axel Conrads (axel@conrads-berlin.de) */ /* */ /* Refer to TechGFX.com for detailed information on PHP-Nuke Platinum */ /* */ /* TechGFX: Your dreams, our imagination */ /************************************************************************/ $dbhost = "localhost"; $dbuname = "name registered in sql"; $dbpass = "PASSWORD"; $dbname = "sql db name"; $prefix = "my prefix"; $user_prefix = "my prefix"; $dbtype = "MySQL"; $sitekey = "7Ed+UratU+e9-eSwASW8s82MagUV*2"; $gfx_chk = 3; $subscription_url = ""; $admin_file = "admin"; /************************************************************************/ /* Database and System Configuration INFORMATION */ /* */ /* dbhost: SQL Database Hostname */ /* dbuname: SQL Username */ /* dbpass: SQL Password */ /* dbname: SQL Database Name */ /* $prefix: Your Database table's prefix */ /* $user_prefix: Your Users' Database table's prefix (To share it) */ /* $dbtype: Your Database Server type. Supported servers are: */ /* MySQL, mysql4, postgres, mssql, oracle, msaccess, */ /* db2 and mssql-odbc */ /* Be sure to write it exactly as above, case SeNsItIvE! */ /* $sitekey: Security Key. CHANGE it to whatever you want, as long */ /* as you want. Just don't use quotes. */ /* $gfx_chk: Set the graphic security code on every login screen, */ /* You need to have GD extension installed: */ /* 0: No check */ /* 1: Administrators login only */ /* 2: Users login only */ /* 3: New users registration only */ /* 4: Both, users login and new users registration only */ /* 5: Administrators and users login only */ /* 6: Administrators and new users registration only */ /* 7: Everywhere on all login options (Admins and Users) */ /* NOTE: If you aren't sure set this value to 0 */ /* $subscription_url : If you manage subscriptions on your site, you */ /* must write here the url of the subscription */ /* information/renewal page. This will send by */ /* email if set. */ /* $admin_file : Administration panel filename. "admin" by default for */ /* "admin.php". To improve security please rename the file*/ /* "admin.php" and change the $admin_file value to the new*/ /* filename (without the extension .php) */ /* */ /************************************************************************/ /* You finished to configure the Database. Now you can change all you */ /* want in the Administration panel. To enter just launch you web */ /* browser pointing to http://ww38.yoursite.com/admin.php */ /* */ /* Remeber to go to Settings section where you can configure your new */ /* site. In that menu you can change all you need to change. */ /* */ /* Congratulations! you now have successfully installed */ /* PHP-Nuke Platinum v.7.6.0. */ /************************************************************************/ /* Thankyou for choosing PHP-Nuke Platinum: Expect to be impressed. */ /************************************************************************/ // Do not touch anything below this line unless you know what you are doing $reasons = array("As Is", "Offtopic", "Flamebait", "Troll", "Redundant", "Insighful", "Interesting", "Informative", "Funny", "Overrated", "Underrated"); $badreasons = 4; $AllowableHTML = array("b"=>1, "i"=>1, "a"=>2, "em"=>1, "br"=>1, "strong"=>1, "blockquote"=>1, "tt"=>1, "li"=>1, "ol"=>1, "ul"=>1); $CensorList = array("*BLEEP*", "*BLEEP*", "*BLEEP*er", "*BLEEP*ing", "*****", "*BLEEP*", "c0ck", "cum", "twat", "*BLEEP*", "*BLEEP*", "fuk", "fuking", "mother*BLEEP*er"); $tipath = "images/topics/"; if (stristr($_SERVER['SCRIPT_NAME'], "config.php")) { Header("Location: index.php"); die(); } ?> Share this post Link to post Share on other sites
iGuest 3 Report post Posted December 31, 2004 i know that problem....you need to make a database, add user to db and put the info in config.php..this part:$dbuname = "name registered in sql"; ----->enter db name$dbpass = "PASSWORD"; ------>enter db password$dbname = "sql db name"; ------->db usernameNeed more help? PM me? Share this post Link to post Share on other sites
iGuest 3 Report post Posted December 31, 2004 i did that already....but i dunno how to add user to db i am not using freenukehosting hosting.... Share this post Link to post Share on other sites
iGuest 3 Report post Posted December 31, 2004 i did that already....but i dunno how to add user to db i am not using freenukehosting hosting.... Do you online at MSN? I'll help you now... Share this post Link to post Share on other sites
iGuest 3 Report post Posted December 31, 2004 i am online added you already... Share this post Link to post Share on other sites
iGuest 3 Report post Posted December 31, 2004 o.k fixed...admins or mods...please closed this thread... Share this post Link to post Share on other sites
iGuest 3 Report post Posted January 1, 2005 thx...naz...btw you rawk Share this post Link to post Share on other sites
iGuest 3 Report post Posted January 14, 2005 how to encry to file config.php Share this post Link to post Share on other sites
iGuest 3 Report post Posted January 14, 2005 What??? Share this post Link to post Share on other sites
iGuest 3 Report post Posted January 15, 2005 wad wad?The problem is fixed Share this post Link to post Share on other sites
iGuest 3 Report post Posted January 15, 2005 Yea...the problem is fixed...he didn't enter MSQL name,username and password in config.php :mrgreen: Share this post Link to post Share on other sites
