iGuest
Need Help
Your best loggin into Cpanel -> MySQL -> phpMyAdmin -> SQL Query -> ajnd chose the upload option and click browse button and then click the Go button and phpMyAdmin will install the database or run the file for you!
Sexydeath, make sure you create a database and a database name and password if you havent already.After you did that go into phpmyadmin, you should see the database name you created click on the name then follow the rest of the instructions that wildteen88 gave you.
SQL Query -> and chose the upload option and click browse button and then click the Go button and phpMyAdmin will install the database or run the file for you!
