iGuest 3 Report post Posted December 18, 2004 Each time I fnish the installation Phpnuke I can not fix myself as admin.Since I can not recieve confirmation email to continue to confirm it. Share this post Link to post Share on other sites
iGuest 3 Report post Posted December 18, 2004 then you would have to go into the SQL database and edit that sort of stuff..Yeah,the mail() fuction of this site isn't very good... Share this post Link to post Share on other sites
iGuest 3 Report post Posted January 2, 2005 edit the msql dbnuke_authors... Share this post Link to post Share on other sites
iGuest 3 Report post Posted January 10, 2005 I have installed several times phpnuke and wen i register for the first time never need to confirm by email. That happens only when a user register . But that can be alliterated in properties admin. Share this post Link to post Share on other sites
iGuest 3 Report post Posted January 14, 2005 or can use a patch for nuke ,,disabling email function ,,you need to find it on the web,,i have done,,but cant find in my files Share this post Link to post Share on other sites
iGuest 3 Report post Posted January 22, 2005 the admin account is http://ww38.yoursite.com/admin.php^^ that is where you should first register/set yourself up. :PIt will not require an email.If your emails aren't working after you do that, themod Midas is talking about is theNo Mail Your Account Hack - found at Nuke Resources. Share this post Link to post Share on other sites
iGuest 3 Report post Posted January 29, 2005 That hapens to me long time ago but it was because a change the config php location. Share this post Link to post Share on other sites
iGuest 3 Report post Posted February 11, 2005 did u fix the problem? Share this post Link to post Share on other sites
