cragllo 0 Report post Posted December 31, 2004 Do you want a drop down menue that is just a drop down menu, or do you want to click te options to go to different pages or sites? If you want to be able to click them, Ill give you the code how, it's got css style with it, lol. Put the following code insite the <head></head> tags... <script language="JavaScript">[/br]<!--[br]function MM_jumpMenu(targ,selObj,restore){ //v3.0[/br] eval(targ+".location='"+selObj.options[selObj.selectedIndex].value+"'");[br] if (restore) selObj.selectedIndex=0;[/br]}[br]//-->[/br]</script> Next, just put this code where ever you want your menu to appear... [/br]<select name=select id="select" style="BACKGROUND-COLOR: #000000; COLOR: #FFFFFF; FONT-FAMILY: Arial, Helvetica, sans-serif; FONT-SIZE: 10px" onChange="MM_jumpMenu('parent',this,0)">[br] <option value="home.html">HOME</option>[/br] <option value="links.html">LINKS</option>[br] <option value="#"></option>[/br] <option value="#">--OTHER SITES--</option>[br] <option value="http://forums.xisto.com/ Web Hosting</option>[/br]</select> If you are going to link to other sites, you have to put in ther 'http//' That is where alot of people go wrong, so on the site, the link will go to 'yoursite.com/www.linkedsite.com' instead of 'linkedsite.com/ I hope this helps you... Share this post Link to post Share on other sites
faceofdie 0 Report post Posted December 31, 2004 For JSP dorp-down menu you can use Nav Studio 2005Its Very nice and cool software for edit drop-down menui like for download this software go to ::http://www.opencube.com/ Share this post Link to post Share on other sites
hulunes 0 Report post Posted January 1, 2005 ohhh,indeed u said is drop menu.i used it in my homepage too.what above list were almost html code and you must add them by <sytle> like css.if you wanna be easy to carry out,you can use the best webpage designing software Dreamweaver mx.in details,you select the behavour from the tool menu.then u will find the fuction offer drop menu,very easily! Share this post Link to post Share on other sites
