PureHeart
The Problem With # Algorithm problem
Given A,K, the definition
A#B = ( Sum of all digits of A * Maximum digit of B )+Minimum digit of B
and following formulas
A
A#A
(A#A)#A
(A#(A#A))#A
Determine and return the minimal number of necessary # to generate K from A or return -1 if there is no possible solution at all.
I am still looking for a solution to this. Any idea?
AA#A
(A#A)#A
(A#(A#A))#A
Each line must have a greater value than the previous one, so we just need to use the formula until the value becomes K, or exceeds it.
value = acounter = 0while (value < k)   value = calculate(value, a)   counter = counter + 1if (value == k)   return counterelse   return -1
"calculate" whould be the function you use to calculate result of the # operator. This is quite easy to achieve, as you can take out the digits from a number by using "% 10 (mod 10)", which gives you the remainder when dividing by 10 (the last digit).
