evought 0 Report post Posted October 3, 2005 For those of you, like me who have taken iTunes and mp3 libraries to their logical conclusion and started digitizing their DVD collection or downloading some of the very good amateur flicks out there (e.g. Star Wreck: In the Pirkenning), you may have run into this:The official DivX codec has some serious problems on OS X Tiger (10.4.x) and Quicktime 7. Problems can include very choppy display, no sound, no display, etc. I experienced a LOT of frustration on upgrading to 10.4 when much of my video library stopped working (and it is such a hassle to have to dig through boxes for an actual DVD ...). Fortunately the fix is easy: use VLC (http://www.videolan.org/vlc/). VLC is a cross-platform (Windows, Linux, Mac, etc) video player which has built in support for XVid, DivX, etc, and plays these files correctly. In some ways, it is much better than the free Quicktime player which comes with Mac OS X, anyway. In particular, it allows you to select with device to send video to and allows me, for instance to play fullscreen video on my TV without tying up my monitor. Share this post Link to post Share on other sites
xboxrulz1405241485 0 Report post Posted October 3, 2005 Well, you can download the DivX library from MPlayer and you can play it with a MPlayer compatible player or any player that only needs its core library and nothing fancy.xboxrulz Share this post Link to post Share on other sites
evought 0 Report post Posted October 10, 2005 Well, you can download the DivX library from MPlayer and you can play it with a MPlayer compatible player or any player that only needs its core library and nothing fancy. xboxrulz 1064324717[/snapback] Hmmm... better than that, it looks like MPlayer now has a Mac OS X package and binaries for Tiger, so I don't even need to play around with the library. It looks like it will work about the same as VLC. I will have to try it and see which i like better. It looks like either way I can use the same media/DVD player on my Mac and my Linux box. Thanks. Share this post Link to post Share on other sites
the empty calorie 0 Report post Posted October 13, 2005 Yup. VLC is the way to go. And it's a fat binary too, so Intel and PowerPC users alike can use it! Share this post Link to post Share on other sites
