vizskywalker 0 Report post Posted June 30, 2005 I am having a problem with some of the php/mysql functions. What I want to do is display the results that a MySQL shell would give a user when executing a query. Using the mysql_query() function I get a resource, but the mysql_fetch_row() and mysql_fetch_object() functions do not seem to be working. If requested, code can be provided, but what I'm looking for is more of an example on how to use these functions or other functions to display the output of a query. Thank you.~Viz Share this post Link to post Share on other sites
miCRoSCoPiC^eaRthLinG 0 Report post Posted June 30, 2005 I'll make it sweet and short...Take a look at this page: http://forums.xisto.com/no_longer_exists/It has straight out examples of how to fetch all databse names, table names, field names and row results using those commands... all sandwiched together - but you shouldn't have problem figuring out. very easy syntax..Regards,m^e Share this post Link to post Share on other sites
vizskywalker 0 Report post Posted June 30, 2005 Thanks, although that didn't have the solution, it led me to the solution. I need to have a user for the server, accessing anonymously was the problem.~Viz Share this post Link to post Share on other sites
