chris1234 0 Report post Posted June 14, 2005 Hello, thanks for trying to help of you can...im sure my proble is fairly simple but not to mee...here is a descriptionTrying to add hyperlink to my website (built in word) which links to a photo album (in the same site, but is independent) (jalbum)but cannot get them to work. I am sure the link is corret (website/folder/index.html),is the problem that the site uses index.html, and then i am linking it to another (in a different folder)? an ideas,thankschris Share this post Link to post Share on other sites
Klass 0 Report post Posted June 14, 2005 Try this: <a href="./website/folder/index.html">Photo Album</a> or <a href="http://your URL here/website/folder/index.html">Photo Album</a> Can you type the full URL in your browser and pull up the Photo Album page? Share this post Link to post Share on other sites
chris1234 0 Report post Posted June 14, 2005 hello, thanks for helping i get the replyNot FoundThe requested URL /antique gallery/index.html was not found on this server.Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.Apache/1.3.33 Server at http://forums.xisto.com/no_longer_exists/ Port 80maybe if you try the website http://forums.xisto.com/no_longer_exists/ it will give you a better idea, i have tried several hyperlinks, none of which work.thankschris Share this post Link to post Share on other sites
chris1234 0 Report post Posted June 14, 2005 ahh just got it working, thanks.just need to tidy it up a bit now, and firefox doesnt display one of the background pictures.thankschris Share this post Link to post Share on other sites
Klass 0 Report post Posted June 14, 2005 Well for starters I do not see the folder "Antique Gallery".The only folders I see are:AuctioneeringAntiquePersonal Web Page_filesPlease make sure you have upload the correct folder/files to be viewed on the webpage. Share this post Link to post Share on other sites
kevinparsons 0 Report post Posted June 14, 2005 Hello, thanks for trying to help of you can... im sure my proble is fairly simple but not to mee...here is a description Trying to add hyperlink to my website (built in word) which links to a photo album (in the same site, but is independent) (jalbum) but cannot get them to work. I am sure the link is corret (website/folder/index.html), is the problem that the site uses index.html, and then i am linking it to another (in a different folder)? an ideas, thanks chris <{POST_SNAPBACK}> You have to have the link point to a page that is already online, or I think you have to publish the site correctly. Instead of typing out the link try dragging it onto the page from the folder list, thats what I do in Frontpage. Share this post Link to post Share on other sites
Klass 0 Report post Posted June 14, 2005 dragging would not work if they are not using frontpage/dreamweaver.I use notepad and I am unable to drag, most online web editors do not allow you to drag.The issue they are having is they are trying to hyperlink to a nonexistant folder/file. Once they upload the correct files the link will work. Share this post Link to post Share on other sites
kevinparsons 0 Report post Posted June 14, 2005 I guess it must just be the frontpage feature. I think its well worth it to get frontpage it makes life so much easier. Plus you get some cool new features. You must have to edit the link manually then. Share this post Link to post Share on other sites
