InfeK7 0 Report post Posted June 13, 2005 Part I – Creating the layer style1. Create a new image any size with a transparent background. These water drops are going to be heavily based on blending modes.Change the blending mode to “screen”2. Right click the layer in the layer palette and go “Blending Options.” A window should open named “Layer Styles” Check mark the “Drop shadow” “Inner shadow” and “Inner glow.”3. Click on the “Drop Shadow” tab and put the following settings in:Blending Mode: NormalColor: BlackAngle: 120Use Global Light: uncheckedDistance: 4pxSpread: 0%Size: 6pxClick Image to Enlarge4. Now click on the “Inner Shadow” tab and put the following settings in:Blending Mode: OverlayColor: whiteAngle: -55Use Global light: uncheckedDistance: 11pxSpread: 0%Size: 7pxClick Image to Enlarge5. Now, click on the “Inner Glow” tab and put in the following settings:Blending Mode: NormalOpacity: 40%Noise: 0%Color: flat blackTechnique: SofterSource: EdgeChoke: 0%Size: 8pxContour: defaultAnti-aliased: uncheckedRange: 50%Jitter: 0%Click Image to Enlarge6. Now, look on the left of the window. On the very top of the menu, there should be a tab that says “Styles.” Click on it and press the button “New Style.” Press “Ok.”Press “Ok” to close the window.Part II – Applying the drops1. Open the image that you wish to add the water drops to. I will be using a white background with a pattern on it.Create a new layer2. Now, using the brush tool with the color “black,” (It must be black!) draw what you want your water drop to look like. I will be using:Brush Size: 13pxMode: NormalOpacity: 100%Flow: 100%3. Look at your Styles tab, you should see the style you just made! If you cannot see your Styles tab, go Windows > Style. Click on the style.The image is finally looking like water!4. Now, while pressing [Ctrl], click on the layer with the water on it. It should make a selection around the water.Choose the background layer from the layer palette. Go Filter > Distort > Sphearize with the following settings:Amount: 100%Mode: NormalYou’re done with your water drop!Tips: I would recommend not making the water drops too big. Also, if you have multiple water drops on one layer, I would recommend sphearizing each drop individually.Part III (OPTIONAL) – Ice chunksSo, you want to make the second stage of H2O. All you have to do is add one thing to the blending options!1. Open the “Blending Options" for the water drops again and activate and click “Bevel and Emboss.” Also click "Texture". Add the following settings for both:Click Images to Enlarge2. Now, look on the left of the window. On the very top of the menu, there should be a tab that says “Styles.” Click on it and press the button “New Style.” Press “Ok.”Press “Ok” to close the window. Share this post Link to post Share on other sites
