DanielSchneid 0 Report post Posted June 10, 2005 FIRST AND FOREMOST - I DID NOT MAKE THIS TUTORIAL (i simply found it, and it was really helpful! i have made a bunch of banners for my friends web site applying what I learned from this.) Icon Tutorials Hopefully this helps all the photoshop user's it really helped me* -Dani Share this post Link to post Share on other sites
finaldesign1405241487 0 Report post Posted June 15, 2005 FIRST AND FOREMOST - I DID NOT MAKE THIS TUTORIAL (i simply found it, and it was really helpful! i have made a bunch of banners for my friends web site applying what I learned from this.) Icon Tutorials Hopefully this helps all the photoshop user's it really helped me* -Dani <{POST_SNAPBACK}> that's tutorials for really beginner users.. but they are really nice explained... Anyway my recomendation is to go for http://www.pixel2life.com/or at http://www.finaldesign.tk/ (this second is my own:) ) Share this post Link to post Share on other sites
Herbert1405241469 0 Report post Posted June 25, 2005 Speaking of icons, I found a really helpful program (freeware ) that you can make Windows Icons with (Make your own recycle bin icon and whatnot).http://www.axiomx.com/PixelToolbox/There's not much too it. I believe all you need to make sure of is that you select less than 256 colors and 32x32 and you should be able to make your own icons. I find the best way to get one is to make it up in Photoshop (by either drawing it or copying a photo of whatever you want) and making that the same size as the icon you are going to make, and import it into the Pixel Toolbox.This program is also really handy for making those favicons used for websites. Share this post Link to post Share on other sites
