Darren0330 0 Report post Posted April 13, 2005 If I draw a flash movie, do I need a plugin to play it on my site?thx. Share this post Link to post Share on other sites
X-Wes 0 Report post Posted April 13, 2005 Yes, Darren0330, you'll need a plugin to see the animation. Most web browsers already have this installed. However, just in case you don't:For modern versions of Internet Explorer, a box should pop up when you try to view the animation asking you whether you would like to install the Macromedia Flash Player. Click Yes and follow the steps.For Mozilla-based products or modern versions of Netscape, you'll want to go here: http://forums.xisto.com/no_longer_exists/I'm very unfamiliar with Opera, but I think the above link works for Opera as well.Good luck! Share this post Link to post Share on other sites
hihihihi88 0 Report post Posted April 19, 2005 If I draw a flash movie, do I need a plugin to play it on my site? thx. <{POST_SNAPBACK}> It is easy to do that . When you finish your flash ,then tou click export to web.it will auto to create a web page contani your flash . Share this post Link to post Share on other sites
chrls1405241492 0 Report post Posted May 2, 2005 At the web, the flash plugin will auto install... Share this post Link to post Share on other sites
