musichere 0 Report post Posted April 8, 2005 Since my last formatting of my Windows XP, the sound playback quality has decreased immensely, not necessarily the quality of the one, but the smoothness of what is being played. There seems to be lots of lag during playback, and sometimes it will go to halfspeed. I think it may be because of RAM, but I've always been fine with my 256 RAM card.Can someone diagnose the problem? Share this post Link to post Share on other sites
nakulgupta 0 Report post Posted April 8, 2005 Are your drivers up to date and correctly installed?? Try reinstalling the latest drivers. Since it was working fine before there should be nothing else causing the problem. Are you trying to play mp3's or videos?? Or the system sounds are also lagging?? Share this post Link to post Share on other sites
finaldesign1405241487 0 Report post Posted April 8, 2005 Since my last formatting of my Windows XP, the sound playback quality has decreased immensely, not necessarily the quality of the one, but the smoothness of what is being played. There seems to be lots of lag during playback, and sometimes it will go to halfspeed. I think it may be because of RAM, but I've always been fine with my 256 RAM card. Can someone diagnose the problem? <{POST_SNAPBACK}> It's probably the soundcard driver, did u use an original driver for winxp that comes with your soundcard? Share this post Link to post Share on other sites
musichere 0 Report post Posted April 8, 2005 I just installed Windows XP and the drivers came with it. Share this post Link to post Share on other sites
jipman 0 Report post Posted April 8, 2005 That's the point, the standard windows driver usually do fine, but sometimes, In your case, you just need to get those drivers to get reasonable sound :Pconclusion : install the drivers of your sound card Share this post Link to post Share on other sites
nakulgupta 0 Report post Posted April 9, 2005 Were u using XP before the format?? If not then u might have to find the latest driver for XP.Which soundcard are you using?? Ill help you find a driver.. Share this post Link to post Share on other sites
heathinc 0 Report post Posted April 10, 2005 Since my last formatting of my Windows XP, the sound playback quality has decreased immensely, not necessarily the quality of the one, but the smoothness of what is being played. There seems to be lots of lag during playback, and sometimes it will go to halfspeed. I think it may be because of RAM, but I've always been fine with my 256 RAM card. Can someone diagnose the problem? <{POST_SNAPBACK}> You might want to see what your ram is and compare it with what programs you have running at the same time.. because that can get the dfcompiuyetre to slow down a lot.. so that is something that is the most important. What type of system are you running aqnd what is the processor speed and the ram size. This can all play a part in the speed and could be the cause of the lag problem. Are you running this sound file through internet streaming or is this finle located on your computer? Thanks, Chris Share this post Link to post Share on other sites
musichere 0 Report post Posted April 15, 2005 I have a feeling it's got nothing to do with the sound card driver since it's always worked up to now. I have to dig out the manual to find out the specific sound drive, thanks for your help, I'll get back to you later with the name of it.I think it's the ram that's the problem. It is only 256, and I love playing music and videos on my computer.The make is eMachines, which as we all know is a pretty awful system for reliability and longevity. I do run a lot of programs at the same time. I use Opera, Azureus, GAIM, eMule, AVG Antivirus, Zonealarm Pro firewall etc. all at the same time without comprimise, so that causes huge lag on my computer and may be the reason for the lagging sound.The processor is only 2.66, which isn't exactly great. Share this post Link to post Share on other sites
musichere 0 Report post Posted April 27, 2005 I've found out that the sound driver that was automatically installed with my computer was Realtek Ac'97 Audio. Does anyone know where I can get this updated or improve it in some way? Share this post Link to post Share on other sites
clarkent 0 Report post Posted May 4, 2005 i have problems with my sound blaster pro Share this post Link to post Share on other sites
musichere 0 Report post Posted May 13, 2005 OK I upgraded the ram to 256 + 512 and that hasn't done anything except cost mst £40...I have no clue and it's annoying me becuase I can't play anything MPEG at all and I use my computer mainly for media... Share this post Link to post Share on other sites
Brian1405241474 0 Report post Posted May 29, 2005 More ram never hurt anyone.Have you tried doing a reformat?It might seem drastic, but sometimes that is all you can do when things get wonky like that.Could it be your speakers? Try using headphones to see if any sound comes out. Share this post Link to post Share on other sites
Brian1405241474 0 Report post Posted June 2, 2005 External sound card might be a good thing to try out.Friend of mine had problems with sound cards and found this and just ordered it. If it works, she will be happy. She was always looking for the latest drivers and tearing into her pc. Maybe you will find one in a store near you! Share this post Link to post Share on other sites
