ThinkEr1405241472 0 Report post Posted November 23, 2004 3d flash animator. a very gud flash plugin to create 3d animations. very easy and simple. the latest version is 3.51u can make simple 3d effects... and if u r very gud. u can also create professional 3d effects. no requirement of professional 3d skills. just install it and use it.Eazy screen saver. well this is also a very kool plugin. u can create screensavers of the animations u made. and then launch them on web :PV2F: video to flash converter. if u wanna make some animation having movie clips.. u shuld use video to flash converter. it converts movie clips to flash file. in form of frames. and u can insert the movie clips into ur animation and make a kool animation.UnlockSwf: if u wanna import some .swf file and when u try to import it says " the file is locked " u can use this tool to unlock it. :oSWF Scanner: for extracting resources from a flash file...! there r hundreds of tools available. but SWF scanner is the best one. Share this post Link to post Share on other sites
