eskick
I Need Help Installing Phpbb Fully Moded PLEASE HELP
I NEED HELP INSTALING PHPBBFM(FULLY MODED PHPBB) CAN ANYONE PLEASE HELP IF THEY GOT AN IDEA BECUASE heres a screenshot it might take a while to load depending on our internet conection:Posted Image please add me on msn at rudeturk@hotmail.com if u want to tell the answer more easyly or just reply thanks for helping :D
[edit]I moved it here from the tutorial section, it's not a tutorial so it don't belong there :D
I'm not sure if this is the correct forumm so if any of you seasoned MOD's think it should be somewhere else, feel free to move it :D [/edit]
Edited by NilsC (see edit history)
Did you post that image of your own hosting account ? If yEs, I would recommend you to use a general image hosting service. You will blow up your BW .
I NEED HELP INSTALING PHPBBFM(FULLY MODED PHPBB) CAN ANYONE PLEASE HELP IF THEY GOT AN IDEA BECUASE heres a screenshot it might take a while to load depending on our internet conection:Posted Image please add me on msn at rudeturk@hotmail.com if u want to tell the answer more easyly or just reply thanks for helping :ph34r:
[edit]I moved it here from the tutorial section, it's not a tutorial so it don't belong there :angry:
I'm not sure if this is the correct forumm so if any of you seasoned MOD's think it should be somewhere else, feel free to move it :blink: [/edit]
56438[/snapback]
I must create database before install forum.
i think the mysql server of the host is already running. it's just that he has not yet setup the right username or password to access or connect to the mysql server.
IF YOUr gettingphpBB : Critical ErrorCould not connect to the databaseThat probably means that your login inffo was probably wrong........ It might be case sensitive so try it out....... It can also mean a few different things....The mysql server may have been down, or it may have not had the proper permission to make the tables.....I would try out the login info first though.....
