MikeH 0 Report post Posted May 19, 2011 I have fairly new [6 months] V3i, which works well 'outwards' but on receiving 'inwards' calls, all sound is absent unless the 'Speaker' button is activated which then distorts the sound considerably. I have tried all around the menus, settings etc. and can find no solution. Can anyone help please before I return the item under warranty. Everything else works well. Thanks Share this post Link to post Share on other sites
