Soviet Rathe
Help With A Mod For My Forum
Ok I got Thanks Mod Light for my IPB forum and it works fine except for one thing.
When you click thanks and the little loading thing comes up but if you click thanks multiple times before the loading is done your name will show up multiple times that you thanked them
like....
The Following 3 users say Thank You person for this useful post
Soviet Rathe, Soviet Rathe, Soviet Rathe
Heres the code for it
// Thanks Ajax Adaptex By ThiagoInfo - Start		if ($this->ipsclass->vars['thanks_mod_enable'])		{			$thank_pid = $row['pid'];				if ($this->ipsclass->vars['thx_topics_replies'])				{					$row['thanks_button'] = "<a style=\"cursor:pointer;\" id=\"thank_".$thank_pid."b\" onclick=\"thanks_add('thanks', '{$thank_pid}', '{$row['author_name']}','{$row['author_id']}')\"><img src=\"style_images/p_thanks.gif\" alt=\"Thanks\" title=\"Thanks\" /></a>";				}				if ($row['pid'] == $this->topic['topic_firstpost'])				{					$row['thanks_button'] = "<a style=\"cursor:pointer;\" id=\"thank_".$thank_pid."b\" onclick=\"thanks_add('thanks', '{$thank_pid}', '{$row['author_name']}','{$row['author_id']}')\"><img src=\"style_images/p_thanks.gif\" alt=\"Thanks\" title=\"Thanks\" /></a>";				}				if ($this->ipsclass->member['id'] == $row['author_id'] || !$this->ipsclass->member['id'])				{					$row['thanks_button'] = "";				}			$thank_text = "";			$thank_text1 = "";			$tquery = $this->ipsclass->DB->query("SELECT * FROM ibf_post_thanks WHERE postid = '$thank_pid' ORDER BY username ASC");			$thank_tot =  $this->ipsclass->DB->get_num_rows($tquery);			if ($thank_tot)			{				$thank_text1 = "<div class=\"row1\" colspan=\"2\" align=\"top\"><strong>{$this->ipsclass->lang['thx_thanks1']} {$thank_tot} {$this->ipsclass->lang['thx_thanks2']} {$row['author_name']} {$this->ipsclass->lang['thx_thanks3']}:</strong></div>";				while($th_row =$this->ipsclass->DB->fetch_row($tquery))				{					if ($this->ipsclass->member['id'] == $th_row['userid'])					{						$row['thanks_button'] = "";					}					$thank_text .= "<a href=\"index.php?showuser=".$th_row['userid']."\">".$th_row['username']."</a>, ";				}			$thank_text = preg_replace( "/,\s+$/", "" , $thank_text);			}			$row['who_thanks'] = "<tr><td class=\"row2\" colspan=\"2\" align=\"top\"><div id=\"";			$row['who_thanks'] .= "thank_".$thank_pid."\"> \n{$thank_text1} {$thank_text}</div></td></tr>\n";			if ($this->ipsclass->vars['thx_member_display'])			{				$thanksquery = $this->ipsclass->DB->query("SELECT thanks_point FROM ibf_members WHERE id = '{$poster['id']}'");						$thanks = $this->ipsclass->DB->fetch_row($thanksquery);				$poster['thanks_point']  = $this->ipsclass->compiled_templates['skin_topic']->member_thanks_point( $thanks['thanks_point'] );			}		}		//Thanks Ajax Adaptex By ThiagoInfo - End
Now in this bit of code
thats the actual button you see on the forum
and heres what ive tried to make the button disable after the first click
$row['thanks_button'] = "<a style=\"cursor:pointer;\" id=\"thank_".$thank_pid."b\" onclick=\"this.disabled='disabled';thanks_add('thanks', '{$thank_pid}', '{$row['author_name']}','{$row['author_id']}')\"><img src=\"style_images/p_thanks.gif\" alt=\"Thanks\" title=\"Thanks\" /></a>";tried"this.disabled='disabled'"this.disabled=disabled"this.disabled="disabled""this.disabled = true"this.display='none'
No matter what I do when I try to modify them I eather get a T_STRING error, or when I click the thanks button nothing happens
I'm still learning PHP so I might be using the codes wrong anyway plz help
