|]4NI3L 0 Report post Posted March 17, 2008 Ok i have had some experience with making Sigs before but this is the first one ive posted on here as i just found just want you all to look at it and tell me what you think of it Thanks. Share this post Link to post Share on other sites
sonesay 7 Report post Posted March 18, 2008 Not bad I like it. There is still some rough edges where you have extracted the render so maybe clean that up a bit. Other then that great. Share this post Link to post Share on other sites
coolcat50 0 Report post Posted March 18, 2008 Not bad. The black looks bad though, you could have made it a pop-out render by making the black transparent. The render does have some rough edges also. The color scheme is kind of strange as well. Green and black are not very attractive together in my opinion. Pretty good though. Share this post Link to post Share on other sites
pugboy 0 Report post Posted March 19, 2008 I also see the edges, but not bad. Better than I could do. Share this post Link to post Share on other sites
chrisid 0 Report post Posted March 21, 2008 I like it alot. But like the others... a bit rough.You could add a slight blur effect toward the back of the render.Hope this helped. Share this post Link to post Share on other sites
