Duckie
Need Help With Urls
OK uh how do i make a script to where it would auto replace spaces in aim names with + but it appears with a space on the site, with the aimgo: url cmd.. so like
asdf asdf sdf
would be in the code:
<a href="aim:goim?screenname=asdf++asdf+sdf&message=boo"></a>
and i have an auto thing, where i add a member, but how would it replace cause like i have a Edit Profile section with lazy ppl forgetting to put the + in between spaces
thanks~
if u have ne q's ask me at aim ARandomDot
thanks in advance
explode takes a string and breaks it up into an array while implode "glues" an array back together, so if you used explode and implode you would have to do something like this:
implode("+",explode(" ",$string));
which is a huge waste of code and processor time.
I would suggest using str_replace if you want to use php for this.
str_replace(" ","+",$string);
If you don't want to use php javascript has a very similar function:
string.replace(" ","+");
If you gave me some code on your website I could help implement it for you.
Edited by alex7h3pr0gr4m3r (see edit history)
