teob 0 Report post Posted November 17, 2004 my pc is connected to the internet though a 3-com 11g wireless router..with firewall...i'm using fileZilla ftp client..the log just say socket error..can't login to my ftp..i'm not good at setting the firewall in the router...is there something i need to set up..? so i can connect to my ftp thought the firewall?please help ...is so troublesome to upload files thought file manageri have set my router DMZ to my ip...edit:i found out that is not my router set up...is my sp2 windows firewall that stopping,,=.= anyway ....thx...if u started replying... Share this post Link to post Share on other sites
DeveloperX 0 Report post Posted January 30, 2006 my pc is connected to the internet though a 3-com 11g wireless router..with firewall...i'm using fileZilla ftp client..the log just say socket error..can't login to my ftp..i'm not good at setting the firewall in the router...is there something i need to set up..? so i can connect to my ftp thought the firewall?please help ...is so troublesome to upload files thought file manageri have set my router DMZ to my ip... Contact to your firewall and router administrator!Check you NAT (Network Address Translation) settings.Can you upload files thought file manager when your firewall is switch off?Maybe you should use another FTP software? Share this post Link to post Share on other sites
adly3000 0 Report post Posted February 4, 2006 (edited) 1- go to http://download.cnet.com/windows/ and downlod FlashFXP it's a FTP program which will allow you to upload your files to your Xisto.com site.(i use it currently) 2- install FlashFXP. 3- try to turn off your firwall. 4- insert your data in the FlashFXP, mine are: * in Server or URL (text box): adly3000.trap17.com * in User Name: my ftp user name. * in Password : my ftp password. P.S you should have you ftp data sent on your email while signing up in Xisto.com, so find them on your email. Edited February 4, 2006 by adly3000 (see edit history) Share this post Link to post Share on other sites
sinmin 0 Report post Posted February 13, 2006 Use SmartFTP instead. I use SmartFTP and it is good.It seem no problem when I use it. Share this post Link to post Share on other sites
antony2kx 0 Report post Posted February 13, 2006 yeah i have that ftp client also and its very good i use it all the time i think other people should use this program also Share this post Link to post Share on other sites
faraz 0 Report post Posted February 16, 2006 some times filezilla not work verywell , i think u must use cuteftp for profesional contact Share this post Link to post Share on other sites
obscure 0 Report post Posted February 27, 2006 i had the same problembut when i used smartftpit was all goooooood^___^ Share this post Link to post Share on other sites
Wimaxxed Expert 0 Report post Posted March 6, 2006 Perhaps it has something to do with the way the FTP/authentication mode. You see... there are two ways: passive, active. It's very likely that the targeted server will only accept passive connections and your ftp client initiates active connections. To check this, try opening a browser and type in the following URL: your_user_name%3Ayour_password%40the_ftp_server Of course you should replace the values above with your actual user name, password and ftp server (like XXX%3AXXX%40XXX) Share this post Link to post Share on other sites
