grnjd 0 Report post Posted October 17, 2005 hey eveybody, i have a problem with file sharing. i want to know how to share files between my laptop and my desktop. my desktop is connected to my laptop with a wireless network. i can also connect it with a ethernet cable. so i just want to know how to share files. i made a network place call \\mycomputer\c\networkplace on my laptop. now i want my desktop to see this "networkplace" folder so i transfer files from my laptop to my desktop. my desktop can't see the folder for some reason. it worked like a week ago, but doesn't work anymore. and does anyone know how to share printers? Share this post Link to post Share on other sites
niloc 0 Report post Posted October 18, 2005 there is a good file and printer sharing tutorial in the tutorial section Share this post Link to post Share on other sites
pawitp 0 Report post Posted October 19, 2005 1. Make sure the network correctly2. Try recreating the share.3. Try mapping the drive of your laptop by using this code net use Z: \\mycomputer\c$ "adminpass" /USER:AdministratorChange mycomputer, adminpass(retaining the qoute) to your configuration Share this post Link to post Share on other sites
amhso 0 Report post Posted October 19, 2005 just make a put the files to share into "my shared folder" and viola, filesharing. or if you have linux, use a samba server. Share this post Link to post Share on other sites
RGPHNX 0 Report post Posted October 28, 2005 Hi yhcln1,If all the advice above fails..then you can get a program called "CheckIT". It has a fast file transfer utility via parallel cable.Hope this is clearRGPHNX Share this post Link to post Share on other sites
magiccode9 0 Report post Posted November 2, 2005 hi, yhcln1, coz you dont have specific OS type and Version. so I have assume this is Windows 2000 or Windows XP. Alone you description, you computer shared folder worked before and then fails. it's might be some system setting has changed.you may try this to repair that. have a administrator right ==> start menu ==> run ==> mmc==> file menu ==>add snap-ins ==> security templates and security configuration & analyis,then, 1.) expand the security template, looking for the setup security and it path, memory it .2.) right-click the configuration & analyis, choose open database and directory location where will be stored the analyis database and result log file.3.) a dialog will prompt you choose template location which is noted in step (1)4.) after step(3), you will return. now. right-click the configuration & analyis items again, then select configure computer now.that it.you system now have initial setting when you have just installed.you may also need to adjust it if you have made change (i.e. take simple shared off if it is windows xp)and try the methods stated by other forum members-hope this help-Eric Share this post Link to post Share on other sites
