lil_chris 0 Report post Posted May 9, 2005 i have just tryed to install a few new scripsts like the chat and the file dateabase one but when i do. its says it as installed but when i click the link to the admin page it just says page can not be displayed why is this? i have tryed 3 now and only 1 work which was the phpwebsite one but it was not what i was looking for so i have uninstalled that one.does this happen with anyone esle and can you help?also why dont fantastico never work?thanks Chris truman aka lil_chris Share this post Link to post Share on other sites
lamode 0 Report post Posted May 9, 2005 what chat scripsts were you trying to install? i think your probably make mistake in your setup, although the Xisto site has a short down time today but that doesn't effect any client site because they are in separate servers. check my msn in my profile if you still have problem with setting up script, i will try my best to help you. Share this post Link to post Share on other sites
cragllo 0 Report post Posted May 9, 2005 This sounds like a common problem, If you dont have the space to install the scripts, not all the files will be installed, make sure you have enough space, (cPanel sometimes does not display an up-to-date ammount of space left)Craig. Share this post Link to post Share on other sites
