GhostKillerX 0 Report post Posted September 6, 2004 i got a very big cd-rom problem it came up when i got home from my vacationokay for some reason the cd-drive couldnt read any cd-keys,and i changed it to a different cd-drive but i don't know how to set it up,snice my new cd-key also got the same problem as my old one Share this post Link to post Share on other sites
Zenchi 0 Report post Posted September 6, 2004 (edited) Have you tried going to the Control Panel -> Add/remove Hardware, then uninstalling it, and reinstalling the drivers? Other then that, best thing I can tell you is buy a new CD-Rom drive. Edited September 6, 2004 by Zenchi (see edit history) Share this post Link to post Share on other sites
GhostKillerX 0 Report post Posted September 6, 2004 i already buyed a new cd-romand for no dam version i can't go to programs that windows made like control panelhappened when i installed windows service pack 2 (you might heard of it) Share this post Link to post Share on other sites
akz 0 Report post Posted September 24, 2004 another sp2 problem.. some hardware becomes incompatible with sp2 and makes it inoperable .. or conflicting... Share this post Link to post Share on other sites
